20 Most Recent Gemini XL-500 Turntable Questions & Answers
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Gemini XL-500... | Answered on Jul 25, 2014
See if you can attach the ground wire to a point on the chassis of the device you are connecting it to.
Gemini XL-500... | Answered on Sep 07, 2012
Hi, slip the ground cable in the side of the rca connection to the device without earth point.It makes no difference if it goes in the left or right jacks. styluscity@gmail.com
Gemini XL-500... | Answered on Sep 13, 2010
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
Gemini XL-500... | Answered on Aug 03, 2010
No! The amp must have a magnetic cartridge pre-amp to increase the sound level. If it has one it will say "phono" on the inputs on the back and have a "turntable" - or "Phono" selector switch. If it doesn't have one (many new surround amps don't) you won't be able to play it properly untill you get a "magnetic cartridge pre-amp". This will make the signal loud enough to be used on a normal aux imput of the Sony.
Gemini XL-500... | Answered on Jul 19, 2010
service<remove>@turntableneedles.com
Try this company but remove the <remove> bit from the link?
Gemini XL-500... | Answered on Oct 20, 2009
HELLO
This should be straightforward. Take off the slipmat and lift off the turntable (platter) and you'll see there is a rim on the underside of the platter this is where the belt goes.
Put the belt round that rim and you'll notice a couple of holes in the platter itself. Hold the belt through one of these holes and put it back on the tunrntable while taking notice of the motor position on the deck.
When the platter is in place (still hold belt) and move the platter to the position of the motor pulley and slip it on. Manually turn the deck once or twice to make sure it is in place - DONE! Replace the slipmat.
ENJOY! (:-)
Gemini XL-500... | Answered on Sep 13, 2009
Typically, one would run a single wire, 18 or 20 gauge will work, from the turntable motor housing to the amp chassis. I know the older amps have a ground screw on them,, but any chassis screw will work.
Gemini XL-500... | Answered on Aug 02, 2009
if there is a slot for a power cord on the turntables them selves then yes you need the power cords
Gemini XL-500... | Answered on Apr 22, 2009
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Gemini XL-500... | Answered on Jan 24, 2009
OK found the solution - need to connect to preamp before my comp.
Gemini XL-500... | Answered on Mar 01, 2008
aaaaaaaaand...........what's your point?
Gemini XL-500... | Answered on Feb 12, 2008
Gemini XL-500 Turntable Logo
29 questions posted
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Vernon Taylor
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Audio Players & Recorders
Most Popular Question
gemini xl 500
  • Audio Players & Recorders
