20 Most Recent
Samsung - Projection TV replacement lamp Projector Lamp Questions & Answers
How to check sony projector lamp
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
4/2/2015 4:03:28 AM •
Samsung -...
Answered
on Apr 02, 2015
No picture
check the video output its either on VGA or AV mode. check your settings. get your manual for that so it can help you a lot.
11/18/2012 7:39:33 PM •
Samsung -...
Answered
on Nov 18, 2012
What is involved in changing bulb in my samsung
There is no lamp in a plasma TV. If you have a "blackout" display, the unit must be taken to a service center for repair. It could be as simple as a blown fuse in the power supply or as complicated as a shorted picture tube--yes, that whole display is ONE large gas-filled tube. Definitely check for warranty status on your unit. Did you buy extended warranty coverage?Have your receipt, warranty info, etc. when you take the unit in...most major suppliers can look up all the info on their computers but, if you have an extended warranty, you'll need that folder with the contract number. Hope I helped you!---Rick
10/23/2012 3:13:07 AM •
Samsung -...
Answered
on Oct 23, 2012
Previously I posted that my Samsung HL56A650C1FXZA
Hello
You have to check the lamp inverter also. If lamp inverter transformers' winding have some trouble [even a short between adjecent winndings inside it] got a short, lamp life wont extent to its lifetime. Thit trouble may be there when you repalce the lamp before 6 months ago. Just replace the lamp inverter board also with this new bulb. Before replacing the new bulb, check your TV thoroughly by any experienced service technician. Checking and replacing the inverter board is acually a skilled work. A damaged inverter transofrmer may even make the bulb exploded. OK.
8/25/2012 5:01:12 PM •
Samsung -...
Answered
on Aug 25, 2012
Have a 50 inch samsung
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
6/16/2011 10:51:01 AM •
Samsung -...
Answered
on Jun 16, 2011
Does a bulb go dim slowly or stop working all at
It can do both, most of the time though you will find that it just goes out completely when it goes. However there are bulbs that just start to dim, it's impossible to predict which it will do, it is random really. If you have more questions please just reply here and I will help you more. Also PLEASE rate my answer 4 thumbs up, it's extremely important to me to have 4 thumbs up... I would be forever grateful if you could do this for me. Thank you! Let me know if you have more to ask.
Tim
10/12/2010 2:13:42 PM •
Samsung -...
Answered
on Oct 12, 2010
Want to find out why the 42' samsung projection tv
The first thing to try is the bulb. If that does not fix it then it is time for a technician to figure it out.Other things it could be are the ballast, power supply board, color wheel or the DMD board; but I would try the lamp first.
6/9/2010 10:00:02 PM •
Samsung -...
Answered
on Jun 09, 2010
Random pixels stay on
Unfortunatly this is part an parcel of modern LCD technology.these pixels are permanently stuck on or off on a particular colour. The only way to fix it is to replace the entire LCD screen and hope that it doesn't get replaced with one that has more dead pixels.
Manufacturers have a tollerance to how many they will accept as ok before they replace the product. Hopefully you can live with these pixels where they are for the life of the set! annoying but normal!
1/17/2010 9:03:36 AM •
Samsung -...
Answered
on Jan 17, 2010
