20 Most Recent SanDisk Sansa e200 MP3 Player Questions & Answers
usb device bug
SanDisk Sansa... | Answered on Jun 09, 2017
When you plug the device into your computer just look at it with the file manager. If you can't see the media files, make certain you have selected in windows "show all files". You need to see the hidden files, including operating files. Be very careful only to delete files that you think are the corrupted media files.
If you are on windows 7 you can look at my blog site which will explain how you can select the options to view all files.
It's under the section about windows media player art problems.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
SanDisk Sansa... | Answered on May 09, 2017
According to the information I found on your player you have to use the included software. See below.
Photo Browser
– supports photo files converted and transferred to the device through the included Sansa Media Converter software.
Go to this website for the users manual, you can download it here:
http://apac.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
Good Luck, I hope this helps
Please rate me,
Thank You
SanDisk Sansa... | Answered on Oct 09, 2015
1. Download recover.rar from here
2. unpack the libusb-win32-device-bin-20060827.tar.gz to (example) c:libusb
3 find e200tool.zip and unpack it to (example) c:e200tool
lots of archives isnt it )))
DRIVER:
1. connect using manufacturing mode (hold button on + center button while connecting)
2. In device manager find unknown device under USB and update the driver. Select driver manually. Navigate to 0781-0720.inf (came with the archive) (c:e200tool)
3. When windows promt you to install "libusb0.sys" direct it to с:libusblibusb-win32-device-bin-20060827in
4. Start-> run -> cmd
5 type:
cd
cd e200tool
e200tool recover BL_SD_boardSupportSD.rom
6. windows will find another usb device so instead of "0781-0720.inf" choose 0666-E200.inf
7 disconnect player and restart it
STEP 3 (recover bootloader)
1. connect player in manufacruring mode
2. Start-> run -> cmd
3 type:
cd
cd e200tool
but before you hit enter press and hold record button (very important)
Step $ (firmware update)
1. connect player in recovery mode
2. copy PP5022.mi4 to 16 mb partition
3 restart player
OK and now If you screw it up - it is not my fault ))
SanDisk Sansa... | Answered on Mar 25, 2015
It seems that the music store only accepts certain kind of mp3 players but also some accounts are closed down if there is no activity on that account for a certain time. I am pretty sure its more than a month though. I would give them a call.
SanDisk Sansa... | Answered on Dec 14, 2014
If the memory card is over 2 GB, the player can not read it because it was only designed to read up to a 2 GB memory card. It is not showing up on your player because it is too big for the player to read. If you get a smaller card, it should woork just fine on your player and you should be able to access it easily.
SanDisk Sansa... | Answered on Nov 26, 2014
generally we need a 3.7v battery in this player which is also used for the classic cellophones. One should try it from India or China where the classic cellphones are still in market. The battery will cost less than 4$ bt the cost of courier or postage will approx 30$ internationally. I will try if u can send me the actual image of the existing battery in case if u want to replace it. I will find the model of the cellphone and then u can buy ur batery from any online shopping website. Check for the battery model number and voltage & amp. I m a banker and have many contacts with cellphone and accessories distributors. u can write me back.. sarveshis4u@yahoo.co.in else try on any of shopping site. i will wait...
SanDisk Sansa... | Answered on Jun 14, 2014
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
SanDisk Sansa... | Answered on May 10, 2014
there is a sliding button beside headphone jack at the top of player, shuffle it left or right and then power on. it must work..
SanDisk Sansa... | Answered on Nov 24, 2013
Wrong section- just clearing the queue
SanDisk Sansa... | Answered on Jul 14, 2013
ya keep on pressing power button it surly solves the problem
SanDisk Sansa... | Answered on Jul 11, 2013
Press the MENU button. Select Settings (the four vertical sliders). Select the second item on the menu.
SanDisk Sansa... | Answered on Mar 19, 2013
SanDisk Sansa e200 MP3 Player Logo
845 questions posted
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Joe Negus
Joe Negus
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
get player english off spanish
  • Audio Players & Recorders
