20 Most Recent
SanDisk Sansa e250 MP3 Player Questions & Answers
My screen is whack!
open it up and take battery out then put it back in put cover on and press on
Unable to download music
Tubidy.com is a website that allows you to download free music online. Here you can download all your searches (songs or videos) without any problems. There is a search bar for songs so you can find your favorite songs and videos. To use tubidy, you do not need to create an account. However, I am sharing a guide -
https://webslosh.com/tubidy-download-mp3-videos/ where you'll find the step by steps guide to downloading music from Tubidy.com. All you have to do is follow the given steps properly.
Blank screen
make sure the battery is fully charged, then disconnect from your computer. Wait a while for the device to cool and try turning it on again. Mine took a few tries but once it sat for a while it didnt fight me again.
Video converter for e250
You can get the Sansa Media Converter from Sandisk's website.
You must use the Sansa Media Converter to transfer videos. If the video is DRM-protected (many of Real's movies are), it may not actually convert. But if the video is DRM-free, then the Sansa Media Converter will perform the conversion and load the video onto the player. The Sansa Media Converter may or may not recognize certain file formats, so you may need to download an additional program such as Riva FLV Encoder to convert the Real video to AVI format first - then the Sansa Media Converter will recognize the file.
-Tha Mp3 Doctor
Audiobook setting
Instead of dragging the audiobooks to the "music" folder, drag them to the "audible" folder - this player only gives full functionality for audiobooks if you are using the Audible audiobook svc. Otherwise it will play the audiobook as one long mp3 file swithout proper chapter breaks, etc.
Sansa e250 cracked screen
I've tried to get a replacement LCD for my SANSA, impossible so far.
There are some PARTS/REPAIR SANSA's on ebay, but must of them with the same problem. There was also a working LCD, I just fail on bidding.
If you can get a working LCD, the replacement is possible with a blower, directing heat to the specifyc connectors area, you can remove the broken one while the glue (some kind of silicon) is warm and flexible, you have to be careful when putting the new one, pins must be aligned, also you should do that whith both (broken and wkring) at the same time, so then you can use the glue still on the pins (golden connectors) area.
I got to remove the broken one and noticed (with my fingers) that the silicon can be used again, but since I didn't use a blower some of the pins (connectors) where damaged. Only halve of the process is confirmed.
Good luck, we'll wait 4 your results if you get a working LCD somewhere..
Loading Music folders
heres the answer to your problem. Edit the ID3 Tags on your songs. The player would determine how it would organize the songs on the player depending on the ID3 Tags of the song.
My e250 will not sync
This player IS DRM-Compatible, but DRM-protected files almost invariably cause problems at some point. Unplug the Sansa, Uninstall all the Sansa software, and reinstall the software. Replug the Sansa. See if Rhapsody will now recognize it. Try synchronizing.
There is a workaround, but it is illegal - you can get a DRM stripper, and then just use Windows Media Player to transfer the now-DRM-free songs.
-Tha Mp3 Doctor
Philips mp3 player wont turn on
Please try to format the player as formatting it will likely correct the issue. Formatting will destroy all data on the player and get rid of any corruption. You would need to right click on the removable disk icon under My Computer and choose format, we recommend using the FAT file system.
The two ways i know how to reset would be to remove the battery or hold down the power button for 20 seconds.
Duplicate Songs
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo
Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
For more details, check:
How to Delete Duplicate Songs
Sansa e250 2GB no work duplicate the song
Hi , new christmas present
One site I found that has videos and movies ready for the Sansa is:
http://sansavideos.xm.com/
Movies, Music Videos, Family Guy, etc.
Once you get the hang of converting videos you find on YouTube and others, you will be having no problem stuffing your Sansa full of them.
-Black651
