20 Most Recent Hotpoint First Edition FEW12 Front Load Washer Questions & Answers
if there is water in the drum it wont open, so you need to drop the drain hose low to gravity drain....then the door should open. sometimes this fault is due to a broken door catch utube is quite good for fitting help.
Hotpoint First... | Answered on Jan 08, 2018
to get to it you need to remove the plug so there is no power to the machine????
take off the top
turn upside down ,
put the screws into the lid as you take them out
remove the dial screw at the back
remove soap dish.. 6 screws
unclip the door seal
take of the front 6 screws
follow the pipe from pressure switch down
there it is to take of and clean there is 3 screws
now you need a dumpy screw driver
Hotpoint First... | Answered on May 20, 2014
get a new lock they are cheap
Hotpoint First... | Answered on Apr 27, 2014
First of all,lay the drain hose down to floor level and let the water run into a bucket or similar, this will empty the washer of water.
the filter is inside the large black hose on bottom of drum.
Undo hose, remove and clean filter
Refit filter and hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve your problem.
Good luck.
Hotpoint First... | Answered on Nov 16, 2013
you may have messed the lock up while the door was braking because of miss alignment-does the door line up now-you may have to replace the lock-cheers Denny
Hotpoint First... | Answered on Oct 19, 2013
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Hotpoint First... | Answered on Aug 06, 2013
Hotpoint
I can't believe you haven't heard about this.There has been a widespread issue with all front loader washing machines with mold on the door seals.i have heard that a wipe-down with bleach helps,but there may be other solutions that are better,maybe someone else on FixYa knows.
Hotpoint First... | Answered on Oct 08, 2012
Hotpoint First Edition FEW12 Front Load Washer Logo
165 questions posted
Top Hotpoint Washing Machines Experts
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint first edition few 12 front
  • Washing Machines
