20 Most Recent Magic Chef CGR3742 Gas Kitchen Range Questions & Answers
2answers
Cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
1/10/2016 1:01:13 AM • Magic Chef... • Answered on Jan 10, 2016
Oven won't come on
Either the igniter is broken or the safety valve needs to be replaced. It costs $125 or so online The repair person may not sell it as cheap besides his labour
11/28/2013 12:23:25 AM • Magic Chef... • Answered on Nov 28, 2013
I have a Magic Chef gas range model CBR3765AGU and
I NEED HELP PUTTING THE DOOR HINGE
11/25/2012 1:02:45 AM • Magic Chef... • Answered on Nov 25, 2012
Natural gas oven won't get hot and stay hot
Most likely the oven igniter has failed. Turn the unit to bake, the gas should come on within 35 to 60 seconds (at the most). If not, replace the bake igniter. DO NOT TOUCH THE BLACK PORTION OF THE IGNITER with your fingers, this is true for old and new.
11/19/2012 9:07:27 PM • Magic Chef... • Answered on Nov 19, 2012
3answers
Oven door on gas range won't open. Apparently
Hello & Welcome to FixYa
This is a common problem that occurs when self-clean cycle is used after a long time or when the oven gets old. Recommended repair is replacing the door latch-lock assembly as the latch mechanism cannot be repaired. Please get back to me if you have any other questions.
Kevin
7/24/2011 4:48:55 PM • Magic Chef... • Answered on Jul 24, 2011
Magic Chef Gas Range
hit cancel
2/4/2011 5:56:17 PM • Magic Chef... • Answered on Feb 04, 2011
It keeps displaying F4 or F2 and will turn the
Sorry to read about your problem, I hope this helps you out.
f4 is the below and f2 is oven to hot
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.
12/25/2010 8:03:21 PM • Magic Chef... • Answered on Dec 25, 2010
Oven does heat up and
you either have a bad spark module or the swithes are bad.if you remove the knobs off the four valve stems and remove the panel you'll see the spark switches,they come all together on a harness and connect to each valve,most likely this is the problem,part number 74007095 and it's around 25 dollars nad the spark module part number is 8215557 and it's around 30 dollars
12/3/2010 1:30:50 AM • Magic Chef... • Answered on Dec 03, 2010
My oven's temperature isn't rising at all.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
11/27/2010 1:57:55 AM • Magic Chef... • Answered on Nov 27, 2010
Magic Chef CGR3742 Hi, I't
heatman101
11/27/2010 1:57:39 AM • Magic Chef... • Answered on Nov 27, 2010
NO heat on bake setting. All other functions
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
11/23/2010 11:19:51 PM • Magic Chef... • Answered on Nov 23, 2010
I just bought a used stove for my step daughter
Probably ... get onto the floor and look for a pilot and thermocouple arrangement. If you find such, light it.
Does the stove say anything about auto igniter on the top?
7/5/2010 2:48:45 PM • Magic Chef... • Answered on Jul 05, 2010
Magic Chef CGR3742CDC (SERIAL #15924202AL) About
Hi
Sounds like a bad bake igniter…It is suggested to replace the igniter. Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about. However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your igniter is getting weak and might need to be replaced. If you've got a weak igniter, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you smell the gas.
You can check for a weak igniter by simply watching the oven when you start it, if the gas lights quickly, once the igniter is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
6/29/2010 5:56:14 PM • Magic Chef... • Answered on Jun 29, 2010
0answers
Oven is slow to heat up to set temperature
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
5/14/2010 3:38:16 AM • Magic Chef... • Answered on May 14, 2010
Magic Chef CGR3742 Gas Kitchen Range Logo
61 questions posted
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Kitchen Ranges
Most Popular Question
turn gas off replace appliance now need
  • Kitchen Ranges
