20 Most Recent Magic Chef CER3540 Electric Kitchen Range Questions & Answers
oven sensor is probably open.. It should read about 1070 at room temp on an ohm meter
Magic Chef... | Answered on Oct 25, 2012
Hi
Error code F7 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Magic Chef... | Answered on Aug 31, 2011
Sorry to read about your problem, I hope this helps you out.
you may just have to turn off at your ckt breaker, more easy than unpluging
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Magic Chef... | Answered on Dec 26, 2010
you need to adjust the offset
1. Press BAKE pad
2. press Up Arrow until 550
3. press and old bake 3 sec until OO appears
4 press and hold up or dn to select the change you want it can go 5 to 35 difference
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Magic Chef... | Answered on Dec 24, 2010
This is a very popular problem with electronic control board. A power failure many times is together with voltage fluctuation and this is just the enemy of electronics. Despite the fact that you have only one small part gone bad in your electronic board and it keeps some factions working like clock, timer it cannot activated the heating elements for broil or bake and the solution is to replace the electronic board part no 2, Clock assembly
Part Number: AP4009004 made by WHIRLPOOL
The above part and all the other parts of your model can be found in the following link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45328&diagram_id=646136#d646136
Magic Chef... | Answered on Nov 15, 2010
Hello there:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
Magic Chef... | Answered on Sep 27, 2010
This is the code that indicates a shorted sensor, the sensor is a metal probe that comes in the oven from the back wall, it is a little smaller than a pencil.
It should have a couple screws holding it in
Magic Chef... | Answered on May 21, 2010
says it all...
F3 F4 Open or shorted oven temperature sensor Replace
Magic Chef... | Answered on Feb 17, 2010
replace thermostat
Magic Chef... | Answered on Jan 02, 2010
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Magic Chef... | Answered on Nov 25, 2009
Function key shorted or stuck
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Magic Chef... | Answered on Dec 25, 2008
That poof that you heard was a shorted wire. More than likely you would not see it, but there is wires behind it.I would say you tripped a breaker or blew a fuse. Did you put the screw back in it that hold it in. If not turn off breaker before you do. Do you have breakers or fuses.
Magic Chef... | Answered on Nov 05, 2008
try manufacturer possible replacement number --appliance repair shop -online search
Magic Chef... | Answered on Jun 11, 2019
Google (Magic Chef)(68hk-6txw)(manual) without parens OR contact Magic Chef directly to request.
Magic Chef... | Answered on Apr 20, 2019
Magic Chef CER3540 Electric Kitchen Range Logo
Popular Tags
26 questions posted
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Kitchen Ranges
Most Popular Question
after self cleaning oven door lock
  • Kitchen Ranges
