20 Most Recent
Magic Chef CER3725AA Electric Kitchen Range Questions & Answers
Magic Chef Broiler won't turn off
If this is brand new you need to get this taken care of under warranty. Any thing you try to do to repair will void the warranty and with all the electronics on this stove you want warranty to repair. Sorry I wasn't much help but you don't want the warranty voided.
When I put the power
the model number is CER3725AA but you left out one letter at the end.there's a computer board in this also the clock assy. everything runs through this,it sounds like the clock assy.is bad or you can check the sensor first but it sounds like the clock.on older machines this would be a runaway thermostat but the computer does this now.first you can try shutting the power off to the machine for 5 minutes to see if it clears the computer,sometimes they have to be restatrted just like your house computer,if that doesn't help you can try changing out the sensor,this tells it how hot it is in the oven,there should be a tech sheet on the back of the top console or down near the draw,it will tell you how to read out the sensor with a meter,i think it's 1080 ohms but the sheet will tell you,if the sensor is good it's gonna be the clock assy.the part numer is 5701M829-60 and it's 180 dollars.the sensor part number is 12001656 and it's around 45 dollars.good luck.
Replaced baking element and still
take a multimeter and assure that you have power coming to the element you need to take off the rear panel of the range as well as the panel that covers the control board assure that you have power going to the control board and then leaving the control board as well if it is not leaving the control to go to the switch then you would replace the control board if it is leaving the control board yet not going past the switch then you would replace the switch any further questions message me back and please rememeber to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Self clean instructions
Sorry to read about your problem, I hope this helps you out.
The model you have given CER2725, does not support self cleaning.
Look at the sticker on the door area..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
I have a magic chef
Hello there:
Magic chef ovens and various other models of ovens have this no cancel feature this is due to the intense heatthat is generated during the cleaning process Normally if you press and hold the cancel button for 10 seconds this may cancel it out but the oven door will remain locked untill he temperature gets back to around 100 degrees see the cleaning temperature are almost around 600 degrees ok also you can unplug the oven and leave it set for at least 1 hour to allow the internal reset feature to reset the oven ok this has been known to take care of this problem too ok
Hope his is very helpful for you
Best regards mike
How do I use the
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problemheatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
My range is a two
You can find a repair service personnel near your location from the FixYa Repair Service directory by clicking this
link.
On the page which opens, you will find the list of contact details of the repair technicians.
Thanks again.
