20 Most Recent Magic Chef 31100 Gas Kitchen Range Questions & Answers
Carbon from the back of the burner. higher flame from the back of the burner
Possible that a fully cleaning of the burner is needed as there can be cases of clogging or even food particles having caught up into the burner over a period of time. The use of a pressurised air to clean will be good as it will be worth while to remove and clean the entire burner assembly.
11/17/2011 9:57:59 PM • Magic Chef 31100... • Answered on Nov 17, 2011
Magic Chef super capacity range.
oven takes to long to heat, broiler works fine, even the clock works it's just not heating fast....the bottom lights up,but not the top?
10/14/2011 8:32:55 AM • Magic Chef 31100... • Answered on Oct 14, 2011
The oven pilote light is
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
4/20/2011 10:52:58 PM • Magic Chef 31100... • Answered on Apr 20, 2011
3answers
Broilerdoes not come on
This is usually caused by a weak igniter. If the igniter is weak it will not allow the safety valve to respond correctly. I recommend replacing the igniter.
Hope this helps.
Shane
2/19/2011 4:00:50 AM • Magic Chef 31100... • Answered on Feb 19, 2011
THE STRIKER IS NOT WORKING. WHAT TO DO?
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
1/26/2011 6:07:31 PM • Magic Chef 31100... • Answered on Jan 26, 2011
Need a replcement burner for the center griddle
i need to know who stoing my 31100 gas kitchen range
1/18/2011 6:29:40 AM • Magic Chef 31100... • Answered on Jan 18, 2011
The lighting of my magic chef oven is inconsistent
heatman101
1/9/2011 4:28:15 AM • Magic Chef 31100... • Answered on Jan 09, 2011
My Magic Chef model 9112XUB
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
12/19/2010 3:11:52 PM • Magic Chef 31100... • Answered on Dec 19, 2010
How to light the pilot
heatman101
11/27/2010 2:13:30 AM • Magic Chef 31100... • Answered on Nov 27, 2010
Oven temp drops to low before burn turns back on
You have a bad oven temperature sensor. It is in the back top of inside of the oven. It changes out pretty easily two screws and pull it out until the plug is visable, unplug the old and replace, push wires into back.
insert scews. Good luck!
7/16/2010 1:03:06 PM • Magic Chef 31100... • Answered on Jul 16, 2010
Oven doesn't heat up
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
5/15/2010 6:34:59 PM • Magic Chef 31100... • Answered on May 15, 2010
Oven does not get hot F1 F7 error message. one burner does not
Hi there
Heres the codesfor you and hope this helps and let me know.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Thank you for writing to fix ya.
Best regards Richard
2/12/2010 6:58:14 AM • Magic Chef 31100... • Answered on Feb 12, 2010
Annoying beep
On models where the keypad and electronic control are one integral part which can not be separated, an F1 error can be caused by a problem in the oven temperature sensor or its wiring circuit. If not it's the keypad.
12/10/2008 1:05:55 AM • Magic Chef 31100... • Answered on Dec 10, 2008
F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
12/9/2008 1:26:54 AM • Magic Chef 31100... • Answered on Dec 09, 2008
2answers
Oven, Broiler will not ingnite
ok try this turn the bottom oven on count to thirty then smack the safty valve with the plastic end of a screwdriver its the square box with two wires on it that the burner tube goes to underneath if it lights replace it
8/7/2008 8:59:05 PM • Magic Chef 31100... • Answered on Aug 07, 2008
Magic Chef 31100 Gas Kitchen Range Logo
36 questions posted
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Kitchen Ranges
Most Popular Question
broilerdoes not come
  • Kitchen Ranges
