20 Most Recent Miele T1302 Electric Dryer Questions & Answers
It takes 3 cylcles to dry clothes
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me
10/4/2010 3:56:46 PM • Miele T1302... • Answered on Oct 04, 2010
2answers
Miele T1 Classic (TDA150) Clothes Dryer Not Heating. Heating Element replaced, No Error Codes
The air flow problem is not the machine. There is probably a clog in the venting system in the house that needs to be cleaned out. When is the last time that was done?
11/1/2023 11:59:24 PM • Miele Dryers • Answered on Nov 01, 2023
My miele rotary iron B995D keeps tripping the eletrics when it heats up
One of the most common reasons is a faulty heating element. Over time, the heating element can malfunction and become unresponsive, causing the thermal safety mechanism to trip your circuit breaker as a safety measure. If this is the case, you might even hear beeping coming from the iron. The only solution here is to replace the element or replace the iron altogether, depending on the make and model of the iron. Another possible reason is an overloaded circuit. If you have too many electrical appliances plugged into one circuit, it can cause your circuit breaker to trip. Try unplugging some items from the circuit and see if that helps. If after this, you continue to have problems, an appliance repair technician is the alternative for a possible repair.
10/28/2023 4:41:07 PM • Miele Dryers • Answered on Oct 28, 2023
Condenser dryer pump not working when dryer is hot
It sounds like your Miele T 494C Condenser Dryer may be experiencing an issue with the pump not functioning properly during hot cycles. It is likely that the pump is overheating and causing it to malfunction. One possible cause of this issue could be a clogged pump filter. Over time, lint and other debris can build up in the pump filter, reducing its efficiency and causing it to overheat. Cleaning or replacing the pump filter may resolve this issue. Another possible cause could be a malfunctioning thermostat that is not controlling the temperature correctly and causing the pump to overheat. If the pump is overheating, it could be caused by a malfunctioning thermostat, which would need to be replaced by a professional technician. It's also possible that the pump may be damaged or worn and needs to be replaced. It's recommended to consult the manufacturer's manual or contact the manufacturer's customer service for further assistance. They may be able to provide more specific troubleshooting steps or recommend a professional technician to repair the dryer. Keep in mind that attempting to repair a dryer can be dangerous if you're not familiar with the proper procedures and safety precautions. Regenerate response
1/17/2023 11:41:40 PM • Miele Dryers • Answered on Jan 17, 2023
Miele professional dryer blows air into drum even after cycle ends
Everything should be off before the program starts and should stop at the end of the cycle. For oddities like that, you need Miele Service. They are all computer diagnosed on the engineer's laptop computer. Sounds like a control board issue, but hopefully can be reprogrammed.
7/3/2022 4:06:34 PM • Miele Dryers • Answered on Jul 03, 2022
2answers
Miele dryer T586C tries to start then stops immediately error code -Pc
it needs service badly, why delay and flood the home why"? call them in USA yp.com find home dryer service. and call. that is what 99.9999% do not. (not me y)
7/3/2022 6:38:01 AM • Miele Dryers • Answered on Jul 03, 2022
Miele Touchtronic T1403: how best to thoroughly clean front vent/filter crevice?
Sounds like you did a pretty good job. In my experience the blockages are in the rear machine vent, the tube, and just behind the external wall vent. You can even find the odd bird nest in there. Also make sure the flaps on the outside open fully and with ease.. Disassembly instructions https://www.google.com/search?q=miele+touchtronic+t1403+remove+front+panel ..
3/20/2022 5:39:37 PM • Miele Dryers • Answered on Mar 20, 2022
I keep getting error code 98 on a Miele T9820 dryer. I know how to reset it but how do I fix it for good?
Page 58 of the service manual says 'No Gas Ignition'. You need a service call as it is GAS appliance. https://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual I couldn't find anything in normal searches. Code 98 is specific to that model. https://www.google.com/search?q=miele+dryer+error+code+98+fix .. ..
3/18/2022 2:07:44 PM • Miele Dryers • Answered on Mar 18, 2022
How do I replace the drain hose in Miele TWF640WP tumble dryer?
It is a condensing dryer, so the small pump is nearer the top than say a washing machine or dishwasher that has them positioned near the floor. Look on the rear for screws to remove the back panel. I would say it is an easy job.
1/15/2022 5:19:09 PM • Miele Dryers • Answered on Jan 15, 2022
Miele t9800 dryer running hot in normal setting
There is a small component above the heating coil. It is your temp regulator. It is a small round component wired in line with everything. should only be two wires and easy to fix/replace yourself. You will need to get the part number off it or have the make and model when you go to get a replacement part for it.
1/12/2022 2:27:49 AM • Miele Dryers • Answered on Jan 12, 2022
How to put back the drum seal on a Miele Honeycomb Dryer T4224C.
Anything here that helps. In my experience Drum Seals are felt, Door Seals are rubber. https://www.google.com/search?q=Miele+Honeycomb+Dryer+T4224C+replace+drum+seal ..
1/7/2022 4:06:52 AM • Miele Dryers • Answered on Jan 07, 2022
2answers
I am looking to buy a Miele Natural Gas dryer and convert it for LPG use. Is that possible? I can't seem to find a conversion kit anywhere online for Miele Dryers.. Thank you
At least one Miele dryer manual mentions a gas conversion kit being available: https://www.manualslib.com/manual/103258/Miele-Touchtronic-T-9820.html#manual . I found this conversion kit: https://www.mieleusa.com/e/-conversion-kit-gas-pressure-stay-dgd-kd-11187610-p . However, this might be for a totally different appliance. When I used Google to look for the part from other vendors, I found information on Steamer parts. Meile may not sell conversion kits or they could restrict the sales to certified technicians. (There could be a liability issue for the company that changed their program.) I wish that I had better news for you. Cindy Wells
9/18/2021 1:44:03 PM • Miele Dryers • Answered on Sep 18, 2021
2answers
I foolishly washed and dried a dog bed for a neighbor and afterwards my Miele Novotronic T 1576 dryer spins but doesn't heat up.
You need to clean it from any traces of fur. Check lint filters and water outlet.
7/26/2021 12:33:30 PM • Miele Dryers • Answered on Jul 26, 2021
Miele dryer dries too hot.
Hello. Is this a gas or an electric dryer? If gas, are you using LP gas (propane)?
2/9/2021 2:12:48 PM • Miele Dryers • Answered on Feb 09, 2021
How will i do waterproofing the dryer Miele T 4422 C
Page 21 of the manual. Is the condenser drip tray cracked? The one I had was piped into a drain. https://www.manualslib.com/manual/103242/Miele-T-4422-C.html?page=21#manual ..
1/31/2021 1:14:42 AM • Miele Dryers • Answered on Jan 31, 2021
How to seal the dryer Miele T 4422 C
It depends on where the leak is? Internal Felt seals are available as spares. At the rear, venting kits and hose can be sealed with hose clips, Aluminium tape, or Duct Tape. https://www.google.com/search?q=miele+t+4422+parts+diagram ..
1/31/2021 12:46:40 AM • Miele Dryers • Answered on Jan 31, 2021
Miele T1302 Electric Dryer Logo
1 questions posted
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
View Most Popular
Miele Dryers
  • Miele Dryers
Most Popular Question
takes 3 cylcles dry clothes
  • Dryers
