20 Most Recent Miele T9820 Gas Dryer Questions & Answers
Where can I find parts for this unit???
Appliancepartspros.com has just about every part for all appliances. After you get the part number U might just find it on ebay for considerably less money!
6/25/2015 9:48:07 PM • Miele T9820 Gas... • Answered on Jun 25, 2015
3answers
Miele 9820 gas dryer not heating
These are the standard things to check out a gas Dryer that is not heating.
If you feel confident!
Trained people like myself make mistakes too but it usually happens when we get too friendly with what we are doing and become complaisant. It can really be bad if a non trained person is jumpy and doesn’t know safety about when or what is suppose to be happening first, second… Or how to arrive at what should be happening and it isn’t. But at this point if your jittery and don’t feel confident, stop and let someone trained handle the rest.
Key to all modern flame (fossil fuel) appliances is a need for ignition. The 2 most common ways to ignite the flame are:
1 Spark (where there is a spark generator that when directed to the area of the flam ignite the main burner or in some cases a pilot flame) and,
2 Direct ignitions, which most commonly uses a silicone or nitride igniter that glows brightly to ignite the flame.
Common to both of these ignition systems is:
Safety first: always a way to prove that the flame is there and burning.
Here after I will address mostly the Hot Surface Ignition (the orange or direct type of ignition), because the spark ignition type of units have been phased out.
Do you get a "glow" the glow (orange in color) is for the gas to be ignited.
No glow indicates the igniter either has a no voltage problem or the igniter is burned out.
No power should flow to the gas valve if you have no igniter. However, you may smell gas and have no igniter intermittently. This can be normal as some safety systems will allow the gas to flow to the igniter area for a few tries at ignition before locking the valve off.. To be safe always turn off the gas to the appliance, burner, or at the gas valve. I will assume you know how to do this if you don’t then let someone trained handle the rest.
If your ready to proceed:
Confirm power to the gas valve area 110V usually and keep in mind that the dryer has to be running at this point on most all dryers. There is little reason for the burner to come on if the dryer is not running, right?
If you have voltage to the gas valve area check the voltage at the ignition directly. Just to be sure your not in a lock out, mode remove power from the appliance for 2 to 3 minutes reapply power and restart and try the dryer (still with gas off). If no power still to the gas valve/igniter there the problem is somewhere other than the area your in. If you have voltage the problem is probably the igniter. The next step would be to check the voltage to the igniter terminals. Voltage there is almost a guarantee the igniter is out. Look for the way the ignition was installed originally and reverse the process getting the igniter in hand so you can be sure you get the correct one for replacement. It may come out in pieces just take all of them you can to keep the area clean. And vacuum opr blow out the rest with compressed air.
If you don't have 110 Volts the problem is in the controls. The electronic ignition safety board, fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. If you check all the controls and have power to the Ignition board where it is suppose to be with it running then it must be out. Other wise you will have to jump around each safety/control to verify which one is open. Also you may have top stop and restart the drier for each component test to keep from locking out the safety on the ignition board.
Clean the duct out while replacing the igniter if so because the main thing that causes igniter burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps. With any luck all you need is a new igniter
Thank you and good luck.
12/7/2014 6:04:02 PM • Miele T9820 Gas... • Answered on Dec 07, 2014
Miele dryer doesn't stop
Stuck buttons have tech inspect
5/17/2014 3:23:59 AM • Miele T9820 Gas... • Answered on May 17, 2014
0answers
No head
Be the first to answer 3/13/2014 4:40:39 AM • Miele T9820 Gas... • Posted on Mar 13, 2014Be the first to answer
0answers
0answers
0answers
0answers
Miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
6/27/2012 11:17:43 PM • Miele T9820 Gas... • Answered on Jun 27, 2012
2answers
Miele 9820 dryer has check
I am adding some pictures to help with the resetting of the thermostat. It is actually much easier if you pop open the top and remove three screws on the top side of the left panel in addition to the three in the back. That way you get more room to work with.Hope it helps.1_22_2012_8_27_01_pm.jpeg1_22_2012_8_27_25_pm.jpeg1_22_2012_8_28_04_pm.jpeg1_22_2012_8_28_35_pm.jpeg
1/22/2012 8:29:52 PM • Miele T9820 Gas... • Answered on Jan 22, 2012
Motor humming and not moving
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/1/2011 2:16:35 AM • Miele T9820 Gas... • Answered on Sep 01, 2011
Miele T9820 Gas Dryer Logo
41 questions posted
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
View Most Popular
Miele Dryers
  • Miele Dryers
Most Popular Question
miele t9820 service manual
  • Dryers
