20 Most Recent Miele T9800 Electric Dryer Questions & Answers
I have a Miele Drayer T9800 - when it turns opposite direction it makes a LOUD grinding sound, Miele has seen it and replaced parts, but they can't make the sound stop. What do you think?
Pretty sure it the impeller has a few broken fins - this causes a loud sound when the machine reverses direct - replace the impeller
3/3/2019 4:47:48 AM • Miele T9800... • Answered on Mar 03, 2019
0answers
0answers
Replace capacitor
always unplug unit when doing that and still be very careful as it contains a powerful electrical charge even when unplugged. u can discharged it be touching a screwdriver between both prongs but make sure screwdriver is insulated
5/16/2015 7:56:44 PM • Miele T9800... • Answered on May 16, 2015
How do I remove the front of my t9800 dryer
remove screws inside of door an two behind control panel If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
3/3/2015 5:03:01 AM • Miele T9800... • Answered on Mar 03, 2015
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual price depends where you purchase it.. $ 20 to $ 45
9/27/2014 5:51:29 PM • Miele T9800... • Answered on Sep 27, 2014
Will this be expensive to fix or could i t be relatively cheap? Drum wont turn, even by hand. Opened up found broken belt.
you need to strip the dryer to bits and remove the drum sounds like you need a new bearing and it needs a dam good clean inside some oil etc the belt has broken because its stuck on one place on the motor check out the bearings and dust etc sometimes the bearing has just dried up and can be soaked in petrol or etc then oild for a day so .. cost = 0 other than a new belt if you feel you can take it too bits and clean it all then its cheep
9/26/2014 8:10:05 PM • Miele T9800... • Answered on Sep 26, 2014
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
9/26/2014 1:02:28 AM • Miele T9800... • Answered on Sep 26, 2014
Dryer drum not turn
It sounds like the belt that drives the drum may have failed. You can check to see if this is the problem by turning the dryer on and listening for the motor running.
8/4/2014 2:11:38 PM • Miele T9800... • Answered on Aug 04, 2014
0answers
Miele T9800 Electric Dryer Logo
109 questions posted
Top Miele Dryers Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Steve Sweetleaf
Steve Sweetleaf
Are you a Miele Dryer Expert? Answer questions, earn points and help others
View Most Popular
Miele Dryers
  • Miele Dryers
Most Popular Question
get blower fan miele t9800
  • Dryers
