20 Most Recent
Miele Novotronic T1515A Electric Dryer Questions & Answers
There is a burned odor
Hi,The
cycling or operating thermostatis often the problem when a
dryer runstoo hot, but there are also other things that can make it run hot also.Here is a tip that I wrote that gives more details about
why a clothes dryer will get too hot.
Clothes Dryergetting too hotheatman101
The dryer is showing anti
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Checked vent, lint filter
If you haven't already, check your limit switches. One of them may have weakened over time and could be prematurely shutting the heat down. These little automatic switches are located close to the burner and blower housing, they usually have two wires going to them, and they are just a little bigger than the size of a quarter. You may have two. Be sure to unplug the dryer first. Hope this helps you. They are fairly cheap to replace.
DRYER IS NOT HEATING BUT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dryer door opens before cycle is finished
The clip on the door is just been used to much, using a small flat head, (if the clip is metal only) you can twist and expand the eye of the clip, if it's plastic and looped you can stick toothpicks and use em as shims to expand the hole. usually the eye has been crimped shut not letting the clamps grab and the wet clothes knock the door open shutting the dryer off. Usually when you got a date or big job promo soon and you were not there to notice the flaw and you find your clothes still soaked ten minutes from the time you were gonna go. LOL
ELECTRICITY IS AT THE OUTLET
Probably the plug end. Take it and see if you can wiggle any of the prongs. Even a little bit. If so it is probably black there already. if so replace it or the cord. If not start checking the cord where it connects to the dryer and follow the wires from there
How to reverse the door
ceskypavel - I'm in the middle of reversing the door on my Miele T1520 dryer. I think I've got it figured out, but I need to put it all back together to be sure it works. I will post my instructions if I'm successful. Regards, voget
