20 Most Recent
Worx 20v Cordless Lithium-ion Electric Handheld Blower Wg545 Questions & Answers
How to remove broken bit in a WORX 176L
pull locking sleeve back as shown on page 3 of instructions. pick up a can of PB blaster dry lube spray can at HD and spray some around bir.
https://www.manua.ls/worx/wx176l/manual?p=3
12/1/2023 12:23:30 AM •
Worx Garden
Answered
on Dec 01, 2023
My spool holder on my worx edger/ trimmer keeps unscrewing itself
ck out this video...https://www.google.com/search?q=spool+holder+on++worx+edger/+trimmer+keeps+unscrewing+itself&newwindow=1&sxsrf=APwXEdfauQkwFmaCtC3ubVCJYTpRDnvb2Q:1687901890446&source=lnms&sa=X&ved=2ahUKEwj70uHEtOT_AhXEg4kEHYYZAUQQ0pQJegQIDxAC&biw=1280&bih=567&dpr=1.5#kpvalbx=_NVebZNnDOImgptQP9a-08Ao_9woops..my bad. you'll have to copy and paste the link. ):
6/27/2023 9:42:40 PM •
Worx Garden
Answered
on Jun 27, 2023
Was using my 110volt worx
Your trigger might have gone bad. Take your handle apart,and check to see if you have power to the switch,you can use a jumper wire to bypass the switch to see if it starts.
6/5/2023 8:38:32 PM •
Worx Garden
Answered
on Jun 05, 2023
Trimmer. Why doesn't locking mechanism hold?
. It's very simple. You press the button on top of the trimmer. Once you press the hand grip and the top button simultaneously, you NO LONGER have to hold down the top button with with your thumb. Once you release the hand grip, you must depress the top button again. This is a SAFETY measure, so the trimmer doesn't run without a contribution from the operator
5/3/2021 12:04:11 PM •
Worx Garden
Answered
on May 03, 2021
Why is chain saw leaking oil?
I have seen on YouTube a video how to fix a chainsaw that is leaking oil.
In all but very exceptional cases there is nothing wrong at all with your chainsaw and it is fine and what appears to be an oil leakage is simply oil that has sprayed out from the chain as it is rotating at high speeds draining from the saw body and guide bar.
1/2/2021 8:22:46 AM •
Worx Garden
Answered
on Jan 02, 2021
2 year old Worx snow blower battery charger says battery is fully charged, but the blower kills after just two seconds of power. What is wrong?
Batteries are capable of telling lies and fooling a charger, even a modern so-called intelligent charger. The only reliable way to test a power tool battery is testing the voltage under load.
2 years old and it is now the third winter your snow blower is seeing and two summers - I wonder what you did with the battery during those summers?
Batteries hate being less than fully charged and a battery that is less than fully charged for many months will emerge less than optimum and even possibly useless.
Modern lithium batteries don't like being completely discharged because when recharged with a fast charger they get quite warm and it is the heat that tends to shorten their lives...
If any of this seems familiar - your battery is probably faulty.
12/15/2020 10:21:05 PM •
Worx Garden
Answered
on Dec 15, 2020
