20 Most Recent
Worx GT (10") 18Volt Cordless LithiumIon Grass Trimmer WG1515 Questions & Answers
Lithium battery for 18v trimmer
I don't think there's anything wrong with this. 5hrs for a high current tool is actually really good! A quality 18v drill can only drive a few hundred screws at most before needing recharging. And that might be 30 mins...
Personally, I recharge all my tools after each use. The charger for this item will have a 'trickle charge' when the battery is fully charged. This will keep it topped off, and ready for use. It won't hurt the battery to keep it fully charged at all times.
Hope this helps!
If this has helped with your solution please give me the appropriate thumbs up. Thanks, and good luck!
I need to remove the
Please unattached the protective cover before you do anything, then remove plastic strings and unscrew middle to do this. You will see a screw to remove the head.
Thanks,
My trimmer does't work longer then 20 minutes.
I hate to have to break the news to you, but it probably never will. The batteries sold with the Worx trimmers are very cheap. I recommend either buying a few extra batteries and keeping them all charged so you can finish the job or buying a gas or plug in trimmer.
I had one of these last year and there is just no way you are going to get any more out of it. Sorry.
Battery will not fully charge
Have you tried to have the battery tested,and or the charger,its definitely one of those,BUT be careful to check what they cost before replacing any parts,your supplier should be able to help,rgds
My worxs gt trimmer will
Link to service and support page:
https://www.worxtools.com/US/Support.aspx
Hope this helps.
If this has been helpful, please leave positive feedback.
How to remove broken bit in a WORX 176L
pull locking sleeve back as shown on page 3 of instructions. pick up a can of PB blaster dry lube spray can at HD and spray some around bir.
https://www.manua.ls/worx/wx176l/manual?p=3
12/1/2023 12:23:30 AM •
Worx Garden
Answered
on Dec 01, 2023
