20 Most Recent Intel 865G Motherboard Questions & Answers
manual
3answers
From whr 2 download audio driver for intel d865gkd
http://13myfreedownloadz.net/04/intel+D865GKD+audio+driver.html
5/21/2014 5:31:03 AM • Intel 865G... • Answered on May 21, 2014
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ? From the manual http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system. 18.April.2014 18.April.2014
4/18/2014 10:07:01 PM • Intel 865G... • Answered on Apr 18, 2014
manual
Intel d865gsa m/b having no
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM is securely seated test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
6/9/2013 11:09:13 AM • Intel 865G... • Answered on Jun 09, 2013
2answers
Gigabyte 865 motherboard GA 8I 865 GVM SOUND DRIVER PROBLEM
none of the mixer lines are muted are they ?
If you double click on the speaker icon in the system tray or go to audio / sound in control panel and check in there.
Also have you got the speakers / headphones connected to the correct port ?
6/6/2013 10:31:00 AM • Intel 865G... • Answered on Jun 06, 2013
Pc analyzer code
What analyer? and what is the problem? If you give details someone should be able to help.
5/13/2013 5:42:31 PM • Intel 865G... • Answered on May 13, 2013
How to identify bios problem
By the BIOS Beep Code, and/or message,http://www.pchell.com/hardware/beepcodes.shtmlhttp://www.5starsupport.com/info/beep_codes.htmProcessor, and Ram Memory plugged in; you should get the BIOS Setup screen.Also; make sure the CMOS jumper is in the correct position.Intel 865G motherboard tells me Nothing.Just that an Intel 865G motherboard chipset is used,http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsetsScroll down.What is the manufacturer and model number of the motherboard; Or,what is the computer manufacturer name, and model number?For a desktop computer it is on the back next to the Windows product key; or up on the side of the computer tower.(Some models you open a door in the Front, and the model number is located down in there)Post back in a Comment.Regards,joecoolvette
12/9/2012 1:44:35 AM • Intel 865G... • Answered on Dec 09, 2012
What is Intel NH8282110 for
Serial no. For processor.
8/9/2012 5:05:31 PM • Intel 865G... • Answered on Aug 09, 2012
I need intel 865 motherboard all drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions they will automatically search for and find the correct driver also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name sound drivers you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/ free program, paid update available
hope it helps
7/9/2012 10:18:21 PM • Intel 865G... • Answered on Jul 09, 2012
Graphics and audio cards compatible with intel 865g
u need to increase ur graphics capability u can buy a graphics card of 2gb (nvidia) and need to install it on AGP slot which is next to pci slot
7/7/2012 7:49:10 AM • Intel 865G... • Answered on Jul 07, 2012
I installed the sound drive but i can not lisen the sound
Did you install the drivers? If not go to the manufacturer's website and install the Audio drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Audio drivers.
6/7/2012 1:40:12 PM • Intel 865G... • Answered on Jun 07, 2012
Motherbord no power
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
10/27/2011 9:05:13 PM • Intel 865G... • Answered on Oct 27, 2011
I have motherboard version ZX-865GV
  • Get your sound drivers from this link:driversdownloadwin7.com.You can also update your other drivers from the same.
9/18/2011 8:17:15 AM • Intel 865G... • Answered on Sep 18, 2011
My woofers are connected to
could be the audio card/driver on your computer but probably just completely gone. Just try to install the driver of it, and make sure that you have also the audio card's driver to make sure that it is working properly...
8/31/2011 9:14:31 AM • Intel 865G... • Answered on Aug 31, 2011
Intel 865G Motherboard Logo
138 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
replace memory cpu suply power not
  • Computers & Internet
