20 Most Recent MSI KT3 Ultra Motherboard Questions & Answers
0answers
2answers
Audio problem
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Msi-KT3-Ultra-Ultra-ARU-VIA-AC97-PCI-Sound-Driver-614-01-4150D.shtml
follow this link and download ur driver and check it
12/6/2012 1:34:30 PM • MSI KT3 Ultra... • Answered on Dec 06, 2012
3answers
Case wiring
Here is the manual, it will have everything you need to know about your mobo:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=273
12/6/2012 1:26:54 PM • MSI KT3 Ultra... • Answered on Dec 06, 2012
2answers
2answers
Recognition of 3gb memory
Are you installing the correct memory type? I have the same motherboard, make sure you are using PC2100 DDR memory. I assume you are using 3 1 gig sticks of mem is this correct?
11/19/2010 10:25:52 PM • MSI KT3 Ultra... • Answered on Nov 19, 2010
How do you rest the bios
The instructions for resetting a bios are given in the user's manual for the motherboard. Check out this link.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=273
There is a JBAT1 connector on the lower right side just above the IDE slots. You can clear CMOS by shorting 2-3 pin while the system is off. Then return to 1-2 pin position. Read the manual page 2-27 for more information and diagrams.
Thanks
7/11/2010 10:11:59 PM • MSI KT3 Ultra... • Answered on Jul 11, 2010
2answers
Noisy chpset fan on MSI KT2 Ultra-ARU
yes, go to Zalman.com and get a cooler if you mobo is out of warranty.
2/25/2010 4:43:54 PM • MSI KT3 Ultra... • Answered on Feb 25, 2010
My audio does not work it was working yesterday
If you are sure that its not the speakers, do uninstall the sound card driver from the "device manager" in the control pane. and then click on scan for new hardware icon on the top and install the audio driver for your sound card, and check the volume of your system also.
if it doesn't work than your sound card maybe dead.
hardware problems occurs due to no earthing in the power supply, so make sure that your earthing in the power supply is working.
hope this will help you fix your sound card.
best of luck!!!
Peace!!!
12/27/2009 10:19:55 AM • MSI KT3 Ultra... • Answered on Dec 27, 2009
I cannot repair my xp
Your out of luck there. Xp setup can only repair systems that are minorly damaged or nearly intact. If it thinks it can, it will. If too many files are missing and/or corrupted, it will just bypass it. Make sure you always backup and obtain a XP setup disc. Just reinstalling is the easiest route.
12/7/2009 7:52:13 PM • MSI KT3 Ultra... • Answered on Dec 07, 2009
2answers
After hook up every thing
check the switch on the back side of the power supply
5/12/2009 2:10:48 AM • MSI KT3 Ultra... • Answered on May 12, 2009
Need help on connecting up motherboard to rest of pc
I downloaded the PDF Motherboard Manual for the MSI MS-6380E Version 1.0, just now.
Let's take a look at that JFP1 header.
This view is looking at the JFP1 header, sitting at the bottom right of the motherboard, TO THE LEFT of the JFP2 header. The JFP2 header is at the very bottom right hand corner. The JFP1 header is just to the left of it. The processor is to the Top/Middle.
Looking at the pins going across the top of the JFP1 header, they are as follows,
2, 4, 6, 8, and there is no 10. There is no pin for 10.
Looking at the pins going across the bottom, they are as follows,
1, 3, 5, 7, and 9.
Pins 6 & 8 are for the Power On switch.
Pins 2 & 4 are for the Power On light, (LED light)
Pins 1 & 3 are for the HarDDrive activity light.
Pins 5 & 7 are used for a Reset switch. (IF, you have one)
Should you not have the Motherboard Manual, go here,
http://motherboards.org/mobot/manuals/MSI/MS-6380E/
(If this doesn't come up as a link, copy and paste it into your address bar, then press the Enter key)
On this page click on ->Download <- to the right of
File: 6380ev1.0.exe Version: - - Release Date: - -
When you do a small window will come up. Click on the empty circle to the left of -> Save.
This file will be saved either directly to your deswktop screen, or your My Documents folder. I don't know how you have your downloads set up to be saved. I save them to my My Documents folder.
Once you see this file, double-click on it. It's a WinRar file. There will be a Microsoft 'Squawk Box' that comes up. "Warning this publisher could not be verified, ya-da, ya-da"
Ignore it! Click on -> Run
Now the WinRAR extraction archive will come up.
Click on Run.
Now go to the PDF file and double-click on it.
There's your Motherboard Manual.
4/13/2009 5:41:16 PM • MSI KT3 Ultra... • Answered on Apr 13, 2009
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
I was using Sony
the reason you get lost is using bummer APPSlike nero or worst. doget Imgburn , free and safe and solid.use test mode.the do a test mode burnit now tells you exactly what fails. (sure does)and this is why, sure is.(filenames too long or?)"I know some units require a specific brand of blank CD" this is not really true.no player or burner has ODD media restrictions on brand. (ODD disk are really PnP disks that have ID track that tells the host what the disk can do, in every possible way)sure there are vast brands that are pure trash sure.just like tires car or the like. BRAND WISE.like old Firestonedeathtires. (cured by new owners)The Imgburn does fail on bogus medialet me explain, gee seen it all I havethe china import CD-r. has the ID track all configured illegallly, is invalid. so the burner warns of that pronto.a blessing that, like :::: illegall(sic), disk size or makers name missing or the burn limits stated are missing (useless hard nut fail here)a burner can not burn lacking this key ID track set correctly by the maker ( a must be good thing)a classic case of pure junk CD-r or DV-R or BD-Rtry TDK and verbatum and end this junk grade folly.
6/14/2022 3:45:01 PM • MSI Computers &... • Answered on Jun 14, 2022
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
four led lights where are they? lost the manual? Desktop mobo. MS-7693 (v2.x) Manboard 970a or 970S? all led x4 status indicators. on mobo top 4 glow means phase 4 power level. page 32. coin cell dead is #1 for all PCs over 5 year and for sure 7. a dead mobo, bios screens dead, that it,???? what gpu card what monitor ? all fans dead? support for vista or w7 , so that? bios HOT KEY IS <del> THEN F11 (BIOS II)? 2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo? THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever. and see bios. and reset bios first and new coin cell first. 7years old that coin is and will be a pain now or soon. a $ 1 fix. gpu card into top x16 slot????? GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl. psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead. that is about it , on this 2011 mobo. no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port. not told.
5/23/2022 4:34:28 PM • MSI Computers &... • Answered on May 23, 2022
MSI KT3 Ultra Motherboard Logo
Popular Tags
15 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
rest bios
  • Computers & Internet
