20 Most Recent MSI K8MM-V Motherboard Questions & Answers
17answers
Ms-7142 ver:1 audio driver i want a free download
Hi, I've tried to find your driver but without results.. :/ better try some professional tool like this one: Driver Update Software for XP Vista 7 8 used it many times, and it's awesome. wish you best of luck Brian
5/20/2020 4:57:35 AM • MSI K8MM-V... • Answered on May 20, 2020
My system is having the motherboard
Check if MB Battery socket has problem. Cheers!!
11/20/2018 7:01:13 AM • MSI K8MM-V... • Answered on Nov 20, 2018
My motherboard is(msi ms-7528)Ineed sound driver
Pls. Give me a my MSI K8MM-V MS1996 Motherboard Audio Driver
8/18/2018 5:28:22 PM • MSI K8MM-V... • Answered on Aug 18, 2018
BIOS won't recognise SATA hdd.BIOS is Pheonix-Award BIOS v6. 00PG. Do you think I need to update the BIOS?
Hi, according to your mobo manual it supports SATA1/SATA2 hard drives so it's recommended to update BIOS, the latest I found it has release date 2006-06-29, you can find it in the folllowing link: Support For K8MM MSI Global
11/7/2017 3:14:17 AM • MSI K8MM-V... • Answered on Nov 07, 2017
6answers
I need msi drivers for an n1996 motherboard
Hello I have provided a direct link to the drivers for your motherboard. The drivers are free to download. Hope this helps.
Click on link below:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
Please rate my solution. Thanks
10/7/2017 6:36:08 AM • MSI K8MM-V... • Answered on Oct 07, 2017
No display on msi 7142 on start up Hi there. When
When you power on does it beep once and then seem like it boots even though you can't see the screen? Does the caps lock light on the keyboard (if you have one) toggle on and off when you press the key?
7/9/2017 3:36:58 AM • MSI K8MM-V... • Answered on Jul 09, 2017
0answers
I have a msi k8 mmv motherboard with a tiger
Clean the dust out of the CPU cooler fins
4/15/2017 4:53:32 AM • MSI K8MM-V... • Answered on Apr 15, 2017
2answers
I need to know the
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
2/23/2016 7:42:07 AM • MSI K8MM-V... • Answered on Feb 23, 2016
Ms 7142 sound driver
Dear, From the link : http://www.driverscape.com/manufacturers/msi/laptops-desktops/ms-7142/879 you can find all drive for your motherboard Thanks with Regard, Ankur Goyal
9/14/2015 9:08:15 AM • MSI K8MM-V... • Answered on Sep 14, 2015
10answers
I want to dowload VGA from MSI Board MS-7142
All drivers and utilities here :)
http://global.msi.com.tw/index.php?func=downloadindex
7/3/2015 4:02:26 AM • MSI K8MM-V... • Answered on Jul 03, 2015
Msi k8mm-v not power on
CHECK THE PSU. RE-WIRE THE ELECTRICS BY THE MANUAL.
6/19/2015 11:24:35 AM • MSI K8MM-V... • Answered on Jun 19, 2015
How to download via vt837r chipset vga driver
Go to MSI (msi.com) website, from there clik on downloads tab.
After that choose Live Update Online option
6/11/2015 6:57:05 PM • MSI K8MM-V... • Answered on Jun 11, 2015
Msi k8mm-v not power on in motherboard
YOU HAVE SOME CONNECTION LIKE THE LED AND FACE PLATE WIRES IN THE WRONG, CONFIGURATION. THIS IS WHAT I RECOMMEND YOU TO DO FIRST. REMOVE EVERYTHING, UNPLUG ALL DEVICES, MAKE SURE THE MOTHERBOARD STAND OFF THAT ARE IN THE CASE IS NOT SHORTING OUT THE MOTHERBOARD. make sure all the hole is the motherboard line up with the stand off where you screw down the motherboard. 1.make sure the cpu and fan & memory is installed and plugged in 2.just plug in the power supply, turn on system, if boots, turn off 3. install video card 1 only,turn on, if okay, turn off 4. install dvd unit, turn on, boots ok,than turn off 5. install hhd, turn on ok, than turn off 6. plug in front panel,usb,other fan, turn on, if ok,turn off 7 install network card, turn on, if okay, turn off if you have any issues with any of the steps above than you will know which unit or item is bad, or plugged in wrong, or not compatible with your unit I KNOW IT IS ALOT OF WORK BUT IT WILL SAVE YOU ALOT OF RUNNING AROUND WITH YOUR HEAD CUT OFF IF YOU NEED MORE HELP CONTRACT ME AT ROD GANDY ON FIXYA.COM, TIPS AND WEBSITE INFORMATION
4/17/2015 3:44:07 PM • MSI K8MM-V... • Answered on Apr 17, 2015
3answers
Hello the drivers can be downloaded here:http://www.msi.com/product/mb/K8MM-V.html#/?div=Driver&os=AllPlease select your windows system.Click on the file for download.Unzip the file before you install the driver.Good luck
1/25/2015 1:49:13 PM • MSI K8MM-V... • Answered on Jan 25, 2015
3answers
I do not know how to install driver of that mother
all drivers available at
http://www.driverstock.com/download-MSI-K8MM-V-driver/14-9-11420/index.html
1/11/2015 10:48:22 AM • MSI K8MM-V... • Answered on Jan 11, 2015
504 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
ms 7142 ver 1 audio driver want free
  • Computers & Internet
