20 Most Recent
MSI K9MM-V Motherboard Questions & Answers
I have a ms 7312
Hello, I've pasted the below from the MSI website for the board:
Main
Memory •
Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
Supports a maximum memory size up to 2GB.
regards,
Nicam49
p.s. don't forget XP supports 2gb max anyway.
MSI K9MM-V...
Answered
on Apr 16, 2017
Ms 7312 ver 1
http://www.cnet.com/products/msi-k9mm-v-motherboard-micro-atx-socket-am2-k8m800-series/specs/
MSI K9MM-V - motherboard - micro ATX - Socket AM2 - K8M800
Part Number: 7312-010R
1 Related Model
GENERAL
Packaged Quantity
- Chipset Type
VIA K8M800 / VIA VT8237R Plus
- Max Bus Speed
800 MHz
- Processor Socket
Socket AM2
- Max Processors Qty
- Compatible Processors
Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
- Manufacturer
MSI Computer Corp.
SUPPORTED RAM
- Max Size
2 GB
- Technology
DDR2 SDRAM
- Bus Clock
800 MHz
- Speed
PC2-6400
- Features
dual channel memory architecture
GRAPHICS
- Graphics Controller
VIA UniChrome Pro
- Memory Allocation Technology
shared video memory (UMA)
AUDIO
- Type
6-channel
- Audio Codec
Realtek ALC655
- Compliant Standards
AC '97
LAN
- Network Controller
Realtek RTL8201CL
- Network Interfaces
Ethernet
EXPANSION / CONNECTIVITY
- Storage Interfaces
ATA-133 - connector(s): 1 x 40pin IDC - 2 device(s)
SATA-150 - connector(s): 2 x 7pin Serial ATA - 2 device(s) - RAID 0 / RAID 1
- Internal Interfaces
1 x floppy
- Additional Connectors (Optional)
4 x Hi-Speed USB
FEATURES
- BIOS Features
ACPI support
MISCELLANEOUS
- Software Included
drivers & utilities
- Width
8.1 in
- Depth
9.6 in
- Package Type
retail
GENERAL
- Manufacturer
MSI Computer Corp.
HOPE THAT HELPS
MSI K9MM-V...
Answered
on Jan 14, 2015
7312 manual
Hello download the manual here:
MSI Global Motherboard K9MM
Check power supply, the ram modules. This is a AM2 socket, check for the cpu is properly inserted in the socket and the lever is closed.
When it stops any bsod ??
Check also for bad caps.
Good luck
MSI K9MM-V...
Answered
on Jan 13, 2014
