20 Most Recent Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Questions & Answers
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guide
how to recover files from USB drive
You may check out this video tutorial also
Kingston Digital... | Answered on Feb 21, 2013
What format is the drive
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Kingston Digital... | Answered on Jan 31, 2013
which operating system ?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
if you can now see your Kingston data traveller
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
hope this helps
Kingston Digital... | Answered on Sep 26, 2012
Which ever it sounds like it has been exposed to a magnetic field, like a stereo speaker.
Gillight
Kingston Digital... | Answered on Jun 24, 2012
it mean ur burned the chip .. it is useless now
Kingston Digital... | Answered on Jan 09, 2012
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a repy
hope this helps you
Kingston Digital... | Answered on Sep 29, 2011
Click "my computer" there you will see the flash drive, you can open it and make a folder and you can drag a file and store it their when you are done and want to remove the flash drive do not just pull it out, your flash may be damage you should eject it properly. good day and best regards.
Kingston Digital... | Answered on Aug 23, 2011
an example of hoe to copy photo's/data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
hope this helps
Kingston Digital... | Answered on Aug 20, 2011
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps you
Kingston Digital... | Answered on Jul 13, 2011
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Kingston Digital... | Answered on Jun 01, 2011
Probably damaged and will no longer work.
Kingston... | Answered on Sep 23, 2017
Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Logo
18 questions posted
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
kingston 8gb flash drive shows 0bytes
  • Computers & Internet
