20 Most Recent Kingston Digital 4GB DATATRAVELER C10 (GREEN) s Hard Drive Questions & Answers
Probably you just copied a shortcut to the location of the files. You need to go back and verify whether this is the case.
Kingston Digital... | Answered on Oct 07, 2014
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Kingston Digital... | Answered on Jan 31, 2013
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motorlike force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else. Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Step 4 to enable it. Otherwise, go to Step 5. Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown, proceed to Step 5. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown, proceed to Step 6. Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
w7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Hope this helps.
Kingston Digital... | Answered on Jan 26, 2013
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Kingston Digital... | Answered on Sep 23, 2012
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Kingston Digital... | Answered on Jun 10, 2012
hope this helps you
Kingston Digital... | Answered on Apr 15, 2012
If you have a pc or laptop, just put your data traveler to any usb slot then the computer detect it as another drive the you can transfer movie, data, installer, or any software you want but their is a limitation it depends on the capacity of your data traveler in terms of gig.(2gig, 4gig 8gig etc)
Kingston Digital... | Answered on Feb 05, 2012
Hello Gwolk,
The Kingston 4GB DataTraveler Generation 3 (G3) USB 2.0 is a durable 4GB flash memory drive for use with both Macintosh and PC computers. It may be used to transfer files from one platform to another, or to carry files and small applications on a continuing basis. Having no moving parts, flash drives are exceptionally durable and reliable for years of use.Simple - just plug into any USB port
Kingston Digital... | Answered on Aug 16, 2011
if you are referring to finding your usb drive on your computer
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Kingston Digital... | Answered on Aug 05, 2011
aremove the write protection first
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
another way
click start all programs accessories open windows explorer click on my computer you should see your drive click to open it also right click select send to desktop to make shortcut
click start click on my computer you should see your 4 GB data it might be listed as a mass storage device
right click then select format
another way is to control panel administrive tools computer management disk management right click on your 4GB datatraveller select format
hope this helps you
Kingston Digital... | Answered on Jul 15, 2011
your pen rive has malfunctioned and there is no way you can get a faulty pen drive working again
Kingston Digital... | Answered on Jun 19, 2011
This is a Flash drive, not a Hard drive. If it is plugged into a USB port on your PC or laptop then the computer will automatically load the drivers for it and assign a drive letter - usually E or F (C is the hard drive in the PC, D is usually a DVD drive). This should work with Windows XP, Windows Vista & Windows 7. Other oerating systems may require a driver to be downloaded (if available).
Kingston Digital... | Answered on May 16, 2011
if there is a switch on the side that changes colour from white to red that is the write protect, you may also have reached the capacity of writes to the card and this is also why it is saying write protected as it cant write to it anymore. These flash drives do have a high amount of writes for its life, but if you have been using it as a memory booster for vista or win 7 then those read and writes will soon mount up.
Kingston Digital... | Answered on Mar 30, 2011
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- Click permissions
hope this helps don
Kingston Digital... | Answered on Mar 07, 2011
Kingston Digital 4GB DATATRAVELER C10 (GREEN) s Hard Drive Logo
24 questions posted
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
get instruction
  • Computers & Internet
