20 Most Recent Samsung LN40B500 40 40" HDTV LCD TV Questions & Answers
2answers
No hv on inverter board bn44-00264a
Check to make sure you have 24vdc input
11/5/2019 3:02:28 AM • Samsung LN40B500... • Answered on Nov 05, 2019
2answers
Tv would turn on, then would go off and the little
Power supply board most likely source, check for rounded tops on capacitors, a common cause.
11/22/2017 6:43:51 AM • Samsung LN40B500... • Answered on Nov 22, 2017
I have a samsung ln40b500p3f that has sound and no picture. You can turn the tv on and the picture will flash on and off about three times then stays off but I still have sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
12/1/2016 1:11:16 PM • Samsung LN40B500... • Answered on Dec 01, 2016
3answers
My Samsung LN40B500P3FXZA LCD HDTV will change
probably you have defect mainboard .
12/28/2014 6:40:34 AM • Samsung LN40B500... • Answered on Dec 28, 2014
0answers
0answers
Tv keeps knocking itself off
Hello, Good day.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.....
5/21/2011 9:47:01 AM • Samsung LN40B500... • Answered on May 21, 2011
My samsung ln46b610a5fxza picture started to have magenta and green and red vertical lines appear on the screen and now they won't go away
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
1/16/2018 12:19:22 AM • Samsung LN... • Answered on Jan 16, 2018
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/18/2016 3:00:54 AM • Samsung LN... • Answered on Nov 18, 2016
How do I troubleshoot my Samsung TV? I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
3/17/2016 10:45:02 PM • Samsung LN... • Answered on Mar 17, 2016
Samsung LN40B500 40 40" HDTV LCD TV Logo
19 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung ln40b500p3f sound no picture
  • Televison & Video
