20 Most Recent Intex 1000 Gallon Swimming Pool Filter Water Pump () Questions & Answers
Two plastic parts came loose from inside my pump
It sounds like a 1 way/flow valve. If you found them in the filter then that's what it would be. Don't worry about refitting as once broken they won't go back in.
1/10/2018 9:50:37 AM • Intex 1000... • Answered on Jan 10, 2018
2answers
Why is my intex pure spa beeping and will not let me start it
maybe a censor is dirty or blocked
1/7/2016 10:49:30 PM • Intex 1000... • Answered on Jan 07, 2016
Intex pump flowrate drops
you may have a dirty filter. Check your filter to be sure. Remove the filter from the pool equipment and see if it runs fine for longer period of time. The filter would be the only restriction in your Intex system for water flow.RodUS Parts Center
2/5/2013 12:38:29 PM • Intex 1000... • Answered on Feb 05, 2013
I cannot get the lid to unscrew so i can replace/clean the filter cartridge for the first time
What kind of screw heads do you need to turn? Please be specific so I can help!
1/22/2013 1:28:46 AM • Intex 1000... • Answered on Jan 22, 2013
How to install the filter on the inside of the
I am not sure what you are asking because the filter is to be installed on the outside of the pool, not on the inside. The manual you got for the pool should show how to install it. If you don't have the manual then the main thing is to connect a hose between the skimmer port of the pool and the suction of the pump/filter and connect the return port through a hose to the return port of the pool. If you can't connect it then you are probable missing some parts. I hope this helps.
8/13/2011 3:48:33 PM • Intex 1000... • Answered on Aug 13, 2011
I have good flow with
Change the filter.
7/29/2011 11:34:28 AM • Intex 1000... • Answered on Jul 29, 2011
Pump motor not operating
The pump is defective and will need to be repalced.
7/10/2011 5:27:29 PM • Intex 1000... • Answered on Jul 10, 2011
Does the pump has to
Yes the pump should be on continuosly to keep the pool water filtered.
7/10/2011 5:25:47 PM • Intex 1000... • Answered on Jul 10, 2011
0answers
Ok my pool has a
if you can't get an answer, heres their toll free number Tel: (800) 234-6839
5/28/2011 5:53:01 PM • Intex 1000... • Answered on May 28, 2011
3answers
Hi- I'm a new intex above ground metal frame pool
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
7/18/2010 1:12:09 AM • Intex 1000... • Answered on Jul 18, 2010
My pump will not **** or blow water it just humms
check might be air bound and have to bled air out of pump-or impeller damaged or jammed with debris usually if jammed will pop breaker
6/11/2010 12:06:53 AM • Intex 1000... • Answered on Jun 11, 2010
What is the HP of an Intex 673R filter pump
It is a pump, only motors are measured in Horsepower. I would expect the HP of this above ground combined pump and filter is so low they would be embarrassed to state. It is measured in Gallons Per Hour flow rate. https://www.google.com/search?q=Intex+673R+pump+specs ..
1/27/2024 5:35:17 AM • Intex Pool & Spa • Answered on Jan 27, 2024
What does U16 mean on my intex hot tub
limited info generic answer u code doesnt show for intex their codes usually start with E this is a manual that has the trouble shooting on page 20 ------- https://www.manua.ls/intex/purespa/manual?p=1 --------- and pg 13 has the codes
7/25/2023 11:59:11 AM • Intex Pool & Spa • Answered on Jul 25, 2023
I wanted to know if when inflating my Intex pure spa it's normal for the bubbles to also go on ? I thought when attaching the inflation hose it would bypass them
Here's the manual with setup information...https://www.manua.ls/intex/purespa/manual?p=9MY bad you'll have to copy and paste the link. :(
6/30/2023 12:46:00 AM • Intex Pool & Spa • Answered on Jun 30, 2023
3answers
I have an e95 error code on my intex spar and it won't let me put the heater on
means temp to low and the last link is the answer from intex they stat to unplug system then replug but when the pump goes that causes same code since no water flow no water flow your pump has failed these pumps are a magnetic with a small ceramic rod to hold it in place the ceramic rod breaks and stops pump -- intex doesnt sell parts or replacement pump ---easy fix is to go to lowes they sell a brass rod about $4 or home depot and in welding isle is a package of brazing rods [[ brass ]] with a flux covering $ 10 dollars clean the flux off and measure rod about 3 inches is needed How to repair Intex PureSpa pump E90 Error 90 Intex Pure Spa E96 slow reset solution these links can assist http://www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action=openFaq&qid=608&lst_prd=853&lst_subcategory=854&frmcontact=
3/11/2023 2:23:58 AM • Intex Pool & Spa • Answered on Mar 11, 2023
Intex 1000 Gallon Swimming Pool Filter Water Pump () Logo
21 questions posted
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
intex pump flowrate drops
  • Pool & Spa
