20 Most Recent
Intex "" Metal Frame Pool Set (56998e) 56998e Questions & Answers
My pool is leaking where
Hi
You don't have much choice in the matter. Either find and repair the leaks using a proper vinyl patch kit with underwater glue ( you can get this at your pool shop) or buy and install a new liner.
Thanks for using Fixya.
Wish to upgrade cartridge filter pump to sand
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
My intex pool is leaking.
MY INTEX POOL RIM KEEPS GOING FLAT AND WE HAVE TO PUMP IT UP TWICE A DAY WHAT DO I DO ??? THERE ARE NO HOLES, WE HAVE TESTED IT
The wind took the pool
Yes, you can buy replacement parts at
www.intexcorp.com. Select your location from the drop down menu. On the next page, you'll see an area that says visit web store. Click on above ground pools from the drop down menu. On the next page, you can either click on metal frame pools or type in the item that you are looking for.
