20 Most Recent Intex Easy Set Pool 15x36 Questions & Answers
8answers
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
6/27/2022 2:30:00 PM • Intex Easy Set... • Answered on Jun 27, 2022
0answers
2answers
Can I use a large hose slid into the top ring of an Intex pool to hold it up
I would wager anything you slide into the ring would need to be air tight. Without the air it would not have buoyancy, Without buoyancy, when the ring gets pushed down, when entering or exiting the pool, the water would overtake the ring.
12/10/2014 10:19:05 AM • Intex Easy Set... • Answered on Dec 10, 2014
I have a intex pool 13ft by 36 in. I dont know how
Salt - spread over pool - sweep in
Acid - mix in bucket (adding Acid to water!!) then spread over top of pool
Bi-Carb - mix in bucket then spread over top of pool
Pool Clarifier - mix in bucket then spread over top of pool.
For amounts - ask your pool guy (or go to pool shop for free testing and they will tell you amounts)
10/15/2014 12:10:24 AM • Intex Easy Set... • Answered on Oct 15, 2014
I just put up a
Well there are two solutions.
1st: fill the pool with water. (yes it will be leaking)
Get a small bowl and put some dish soap in it.
Next tape a sponge or a rag (or something you can apply the soap with) and scrub down the sides with the soap. Because the soap reacts with water and releases oxygen (or Co2, I'm not sure) when it does, it will bubble up and reveal where the leak is.
I think that's the most reliable way. Another way is only reliable if the leak is large. You can make everyone get out of the pool and listen very carefully at each side. If the leak is large enough you'll hear a sizzling.
I think that the first method would be more efficient, but the second sounds like it might do the job as well and would be easier.
To fix the hole, I believe that you'll have to fix it with a patch kit. The link below lists a few different options. It's essential to have a patch kit when you have a vinyl above ground pool because it's incredibly easy to get a hole in the side. I'd suggest buying a quality patch kit to insure that the patch lasts. You don't wanna waste the 120+ dollars on annoying recurring holes in the side.
http://www.google.com/search?rlz=1C1CHMY_enUS340US340&sourceid=chrome&ie=UTF-8&q=vinyl+pool+patch+kit#q=vinyl+pool+patch+kit&hl=en&rlz=1C1CHMY_enUS340US340&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=y_38TZi-N7LTiAKQ7dmIBQ&ved=0CEoQrQQ&bav=on.2,or.r_gc.r_pw.&fp=731789854f5bd5b4&biw=1280&bih=685
9/20/2014 3:32:57 PM • Intex Easy Set... • Answered on Sep 20, 2014
How do I fold my intex 15' X 36" round pool liner to put away for the winter?
fold carefully youll never get back in original box wrap in a tarp
9/19/2014 1:36:45 AM • Intex Easy Set... • Answered on Sep 19, 2014
Will pool collapse if ring loses all air
find leak fix with a pool patch
8/27/2014 2:12:39 AM • Intex Easy Set... • Answered on Aug 27, 2014
How do i get the water ungreen
super shock pool and keep cleaning filters
8/9/2014 4:39:49 AM • Intex Easy Set... • Answered on Aug 09, 2014
Pump lights come on and go off after 2 seconds pump doesn't start
bad pump motor
8/9/2014 4:38:46 AM • Intex Easy Set... • Answered on Aug 09, 2014
Intex pool water clear dusty brownish green on
you need to get rid of the algie and shock the pool
5/22/2014 2:08:37 AM • Intex Easy Set... • Answered on May 22, 2014
Ring doesnt keep air
Put some Ivory dish soap, about a tablespoon, in a quart bottle with a sprayer, and fill the ring with air. Then start spraying the soap solution all over that ring. When you see "Bubbles" appearing, that is where the leak is. Patch it. Fill with air & repeat. If no more bubbles, you have fixed it.
5/18/2014 11:36:01 PM • Intex Easy Set... • Answered on May 18, 2014
The best way to clean sticky inflatable ring on
ajax or comet
3/22/2014 12:18:38 AM • Intex Easy Set... • Answered on Mar 22, 2014
0answers
Air leak
Be the first to answer 1/27/2014 9:00:10 AM • Intex Easy Set... • Posted on Jan 27, 2014Be the first to answer
Intex Easy Set Pool 15x36 Logo
133 questions posted
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Intex Pool & Spa
  • Intex Pool & Spa
Most Popular Question
top inflatable ring intex pool leaks
  • Pool & Spa
