20 Most Recent
Disney High School Musical Mix Max Plus MP3 Player Questions & Answers
My daughter just got a missil A940LCD2pk for her
It is possible it spent too long in transit from China and the battery died.
I suggest you reread the instructions to ensure you did everything right and if it won't work as per instructions it must be faulty and should be returned ASAP to the retailer for refund or replacement.
Como hago para registrame en hotmail ayudenme x fa
Welcome to fixya
I have a solution for this
Content
Vas a tener que registrar por una cuenta por gratis
Your pre-solution is located above. More information is available
in the comments
My name is Bruce
Mix Stick software
If you have XP just plugin the Mix Sticks. You'll see as an external USB mass storege and you could copy mp3 files on it
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
