20 Most Recent
Microsoft LIFECHAT LX-2000 RETAIL Headset Questions & Answers
Headset not working
Try to connect it to another device that it fits to make sure the headset is the problem. Try reinserting the headset pin into the receiver hole with a slight turn to clean off the contacts in the unit.
1/2/2013 11:52:33 PM •
Microsoft...
Answered
on Jan 02, 2013
No funciona el microfono
Fijate que el control de volumen de grabación esté puesto en "Micrófono", su volumen sea alto y no esté enmudecido. Esta es la principal causa de las fallas en los mics.
Steelmith
6/21/2011 5:52:53 AM •
Microsoft...
Answered
on Jun 21, 2011
Does the Microsoft LifeChat LX-2000 Headset work
Yes, every head set is capable of receiving audio sounds only require the type of connectivty. For example, the headset may require pin connection so long as the device PS3 has audio outlet. Also, wireless headsets that communicate by wii fii would require powering on the wireless signal acquirer. Thereafter each device should ascertain signal transfer. usually, the PS3 would require powering on any wii fii accessibilty buttons to search an acquire wireless signals in this situation audio.
1/13/2011 1:17:16 AM •
Microsoft...
Answered
on Jan 13, 2011
Mac computer doesn't hear voice when using rosetta stone
I have windows, so I don't know if this will help, but I found that you have to make sure that the recording device is named "Microphone HS" or something with the word "microphone" in it. For some reason, rosetta stone does not recognize recording devices unless they have the word "microphone" somewhere in their name.... This is true for windows, I don't know if this is true in Mac. At least this may point you in the right direction. :)
3/3/2010 4:20:26 PM •
Microsoft...
Answered
on Mar 03, 2010
I have installed the software and connected the
plug in the headset first then install the software . i had the same thing happen to me . so i just plug in the headset first then installed the software . it works just great now . ok. frank.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
