Check the drive belt
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected].
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
SOURCE: Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
