Here is what the F-13 error code means and the fix for it.
F13
Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If
failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
To whom it may concern,
I have a Frigidaire Elements stove. I went to preheat my oven to fix dinner and got a constant 'beep' and a code, F13 ERR! Could you please help me with this problem? The stove top works fine, it's the oven that is having major problems.
Thank-you,
anxious to bake in Indy
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Hi
F13 is a door lock error which means that the door lock is
bad and should be replaced. To unlock the door you can leave it unplugged for
around 10 minutes and the door will unlock. Hope this helps...please post back
for further assistance.
Daniel
