Try to reinstall the audio driver and it should work. You can find your driver here:
https://support.lenovo.com/bg/en/downloads/ds003110
SOURCE: lenovo R61 - no recording device installed what do i do?
Please install the audio drivers. The cd utility probably enclosed in your PC from the vendor. insert the cd then install all the drivers and specially the audio driver.
may this help,
melnavz
SOURCE: lenovo G3000 38Q - built-in mic not working under
I believe the problem is that your mic isn't working properly so follow these instructions:
1: Go to control panel and click on "sound"
2: When the sound window opens click on "recording" you should find the built in mic there in the dialog.
3: Click on your built in mic and click on configure.
4: Then, click on "levels" and set the microphone level to 50 and the microphone boost to +20.0dB
If that doesn't work try doing a system restore.Or you could try restoring the defaults on the sound pref.
SOURCE: i need base system device
try this link
remember to give a positive feedback for my help
http://www.recovery-cd.com/related/download/driversdownload/download-drivers-for-base-system-device-for-lenovo-3000-C200.html
SOURCE: How to record from sound card on Lenovo T430
If you can play a MP3 music file already, why would you want to record it?
If you want to convert the MP3 file to a WAV file all you need to is use a conversion program.
Click on this link for instruction on converting music files to mp3 or WAV file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Testimonial: "The first answer was not applicable but after I clarified my problem the second solution was a bingo. Excellent"
