You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
