20 Most Recent Viking VDB200 Dishwasher Questions & Answers
The lights of my Viking dishwasher VDB200SS are
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
10/17/2011 6:54:46 PM • Viking VDB200... • Answered on Oct 17, 2011
Viking VDW302SS--leaking in the front
4/5/2023 4:27:36 AM • Viking... • Answered on Apr 05, 2023
Viking VDW302SS--trying to pump out water that isn't there
If your machine is trying to pump out water that is not there, check the float level sensor. That is the detector that checks for water level during filling. If the pipe/mechanism is blocked, in the full position, the sensor will indicate that there is still water to be pumped out ... that is assuming the water has been pumped out otherwise look for a blockage in the outlet pipe.
3/12/2023 8:07:32 PM • Viking... • Answered on Mar 12, 2023
Model FWD101. Why does it continue to run as though the pump is trying to drain?
Could be a defective cycle timer or a defect in something controlled by it
1/5/2021 2:31:53 PM • Viking... • Answered on Jan 05, 2021
Model VUD141. Why doesn't it turn on?
Could be a defective cycle timer or a defect in some element controlled by the timer
12/7/2020 3:57:28 PM • Viking... • Answered on Dec 07, 2020
Viking professional. Why isn't it turning on?
Could be a defective cycle timer or a defect in an element controlled by the timer
12/7/2020 3:55:03 PM • Viking... • Answered on Dec 07, 2020
Viking dishwasher squeals at end of cycle. It is very loud and then the unit shuts down
Possibly something stuck in the pump
12/7/2020 3:45:51 PM • Viking... • Answered on Dec 07, 2020
Nodel VUD040. Why doesn't it fill with water?
Could be a stuck float valve
12/7/2020 3:24:25 PM • Viking... • Answered on Dec 07, 2020
Model 301. Why does it fill and drain but doesn’t spin the arms and wash?
Wash Pump not working. Drain Pump is working. Wash arm jets blocked. Wash arm jammed.
11/23/2020 8:47:55 PM • Viking... • Answered on Nov 23, 2020
2 related questions. The first is that when I pull the top rack of my Viking dishwasher out, the rack extends too far out and escapes the track on the left side (pic). Also, as soon as I open the door, the top rack starts slowly sliding out on its own. Any help would be great! Thank you.
Your dishwasher probably isn't level front to rear. As for the track problem, there could be a missing stop or some damaged hardware. The racks are supposed to be removable but not on their own.
11/11/2020 2:16:57 AM • Viking... • Answered on Nov 11, 2020
My Viking D3 Dishwasher - at start of cycle, it sounds as if it is working. However, the timer never counts down, the detergent is never released, and little-to-no water is released into dishwasher.
Let’s assume the dishwasher is working correctly because it turns on but nothing else works. If a dishwasher does not fill with water at the correct level, it will not continue to advance. You’re not getting water. Check hot water valve under sink. The one for dishwasher. Maybe someone shut it off on accident. Also,
Water deposits like lime, calcium will build up and clog the screen on the dishwasher’s hot water intake valve.
That would need cleaned out. The valve itself will go bad alone. Regardless, once it’s getting water the dishwasher will run. Please let me know!!
4/5/2019 7:03:46 AM • Viking... • Answered on Apr 05, 2019
My viking dishwasher vud141 washes fine but will not eject the last wash water before it starts the dry cycle. Filters are clean Whats up?
Check for bent drain hose, make sure it’s not push in to far down in to drain trap, if it’s hooked up to garbage disposal check for blockage at that connection and what u want to do is see how good of the stream comes out from the end of drain hose just get big enough backer and fill unit by start cycle then drain unit by canceling cycle will put unit into drain mode
This will give you some ideas we’re to look for problem
2/9/2019 9:41:20 AM • Viking... • Answered on Feb 09, 2019
Viking DW DFUD 142. (DW 20.3) Lower sprayer doesn't seem to be working properly (dishes on bottom staying dirty). Upper one fine. no clogging in lower sprayer. Any suggestions as to problem?
I would expect that something may be fouling the lower arm, thus not allowing it to spin properly.
11/20/2018 11:14:43 AM • Viking... • Answered on Nov 20, 2018
Viking VDB200 Dishwasher Logo
4 questions posted
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Viking Dishwashers
  • Viking Dishwashers
Most Popular Question
lights viking dishwasher vdb200ss
  • Dishwashers
