My costumer printer Epson L655 error scanner 4D, open scanner unit, find the motor that rotate 2 white gear, in this case, reposition and tighten the motor scanner screw, the problem solved.
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
Which means Tachometer (tacho) coil on the motor may be faulty. This coil reads a
magnet as the motor turns to detect the speed that the motor is spinning
at and this in turn allows the electronic controller to set the motor
to revolve at different speeds for the various program options.
52 is an internal scanner hardware error. Unplug printer, wait 30 seconds, plug it in and power up. Problem still there...make sure printer is plugged into wall outlet, not surge protector. If error persists you will have to get the laser/scanner assembly replaced. We arn't talking about the scanner/copier assembly at the top of the printer. This is the internal laser/scanner that is used for all your printing.
52.x PRINTER ERROR alternates with
To continue turn off then on
Possible printer control panel error messages52.0 PRINTER ERROR52.1 PRINTER ERROR52.2 PRINTER ERRORDescription
A temporary printing error occurred. The x
can equal one of the following:
0 = Scanner error
1 = Scanner startup error
2 = Scanner rotation error
This error can also indicate a problem with the shutter tab on the print cartridge.
Action
Turn the printer power off, and then turn on the printer power.
If the message persists, check the print cartridge for damage.
