20 Most Recent
HP LaserJet 2300d Printer Questions & Answers
Hp 2300 laserjet printer error code 13.20.00
this problem persist NVRAM resetting
To perform an NVRAM initialization, complete the following steps:
1 Turn off the printer.
2 Press and hold (DOWN arrow), and turn on the printer.
3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow).
4 Press PAUSE/RESUME. The first item of a menu appears.
5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
cihat ALTIN FROM TURKEY ANKARA
Have HP Laserjet 2300d (Q2474A) printer that won't
Make sure the printer is plugged into a functioning wall outlet supplying the proper voltage (110V or 220V).
If you are using a surge protector, extension cable, or power strip, plug the printer directly into the wall outlet.
Press the power button to turn on the printer.
If the issue persists, unplug the printer and wait 15 minutes.
After 15 minutes, plug the printer back in and press the power button.
If the issue persists, try a different power cord (if available).
Regards,
J Wick
Hp2300 laser printer
52.x PRINTER ERROR
alternates with
To continue turn off then on
Possible printer control panel error messages
52.0 PRINTER ERROR
52.1 PRINTER ERROR
52.2 PRINTER ERROR
Description
A temporary printing error occurred. The
x
can equal one of the following:
0 = Scanner error
1 = Scanner startup error
2 = Scanner rotation error
This error can also indicate a problem with the shutter tab on the print cartridge.
Action
- Turn the printer power off, and then turn on the printer power.
- If the message persists, check the print cartridge for damage.
- Verify if the shutter tab on the cartridge is broken or damaged. click on the below link.
Shutter tab on the print cartridge
1 - Shutter Tab
- Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer
SoftwareRegards
Chittaranjan
Hp 2300dn. Why does double-sided printing blow the house fuse?
I have to say that this is one of the oddest questions I have been asked. The only real difference between single sided and duplex is that there is one solenoid and the drive motor reverses direction. Neither of these actions are directly connected to the power supply. Might be that there is a short. I would try a different outlet first.
Hp 2300d paper stops at exit roller
Probable causes: First have you tried running the paper thru the manual feed tray and see if it stops at the fuser unit.. if so then proceed with checking the exit area of the printer(fuser) and make sure there is no obstruction blocking the path, could also be the fuser actuator, small black arm generally pushes the paper during it's delivery(exitiing) of paper.. Worst case scenario is a paper feed timing issue.. but first check the exit area of the printer and the paper tray. If you need further help, reach me via phone at
https://www.6ya.com/expert/howard_563901c2e8628759
Printer jam after first copy
- If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
- Always remove all paper from the paper tray and straighten the
stack when you add new paper. This helps prevent multiple sheets of
paper from feeding through the printer at one time and reduces paper
jams.
If you need any technical help on printer then you can reach at here
I am having HP 2300
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Out laser 2300 printer has
All three lights flashing indicates a general failure. this is caused by either a bad connection, a bad formatter or a bad engine control board. Disconnect any cables you have attached to the printer and restart. If it starts fine then you may have a bad cable. If this is a networked printer, then it is quite possible that the network card has failed. You can try removing the network card if it has one and restarting. The JetDirect 615N card that shipped with this series of printers is notorious for failures.
Feed switch switch seems loose
When you changed the roller you knocked the sensor out of place. Normally when you change the roller you want to release the right side roller lock first so that you can retract it and it keeps everything in place. You will need to remove the roller and then move the sensor lever on the roller shaft until it is in the correct position and them reintall the roller. This is sometimes easier to do if you tilt the printer on it's back so you can see what you are doing. Remove the toner cartridge first.
I installed a new cartridge
first verify it's the new cartridge, if possible replace with another to confirm cartridge problem, and if so just install another one.
but if it's not the cartridge it could me a number of reasons, from a bad fuser leaving marks or a scanner failure or even a charge problem.
need to first eliminate the obvious. If you need further help, reach me via phone at
At work I have a
first what size is tray 1 set for and the type. generally tray 1 is set for letter size and the type is plain and usually is the normal default configuration.
also check the tray guides for proper setting letter size..
Also if possible run a configuration page to see how your current paper handling settings are being read by your printer.
the MP Tray is generally setup as ANY Size and ANY type always.
check your paper handling setup settings..there are additional steps, let me know. If you need further help, reach me via phone at
Can't clear
Thanks for writing to Fixya.com.
This is a problem with the NVRAM resetting. In order to clear it please perform the above steps:
Thanks for contacting Fixya and please accept the solution if it has helped you.
In our office we have one Laserjet2300d printer
make sure you have set up your computer's network in file and printer sharing is on..
if you have never done it before...
here is how you will do it..
click start
my network places
on the left side of the window you can see this "set up home or small office network"
click it and a dialog box will appear
click next
next again
just next again
asign a computer name that you want
check what is your work group name if there is any..if not just use the default then next again
turn on file and printer sharing then next
then wait until it is finished
sometimes if it is your first time to set up it
it needs to restart your computer..
and now you can print your document via lan printer..
I have hp deskjet 2300d showing that their is a
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
