SOURCE: what products to us in my jet bath
Bubble bath is definitely out of the question. Provide any of the products that you are using do not have a detergent base or bubbles so to speak, you can use them. Depending on how many times a week you use it you might want to get a cleaner that they use on hot tubs from you local pool distributer. I hope this helps you.
SOURCE: jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
SOURCE: I know I can take a bath without turning on the
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
SOURCE: stale water odour when jets havent been used on massage type spa
There are several cleaning methods on the internet. I would contact the maker of the tub and see if they have a cleaning agent. I know that Jacuzzi and Aquatic industries have a cleaner that works rather well. I have seen one on the net that uses 2 teaspoons of powder dishwasher soap mixed with bleach. I have not tried this one so don't know how well it works. The ones from the tub companies are not cheap, but if you want something that is going to do the job, spend the money.
SOURCE: Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
