Moen 4621 Chateau 1 Handle Bathroom Faucet W/drain Assy Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace a new drain plug when it has been detached from the stem / handle? I cannot see the ball nor anything to attach the new drain plug to to raise and lower the plug.
Joe Maestro
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Jul 16, 2011
 Joe Maestro
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
64611
Points
563
Look at the back of the drain pipe directly below the sink. There is something that resembles an oversize nut that can be turned; turn it like a nut to loosen it. As soon at it is completely separated from the threads, hold on to the nut and the rod that goes right through the nut. Using one hand to hold onto the nut and rod at the same time, push the rod into the drain and rotate it downward a little. Drop the new drain plug into drain with the tab (with a hole in it on the bottom) facing away from you with the other hand. Now comes the slightly tricky part. Use hand to hold onto the nut and rod and use the other hand to hold onto the new drain plug in the correct orientation. Back off the rod away from the drain a little bit and drop the drain plug a little to align the hole (on the tab) with the rod. Now move the rod back into the drain and ensure that you've inserted the rod onto the new drain plug by rotating the rod up and down. Once everything's in place, tighten the nut back. The nut should be tight, but not too tight or the drain with be hard to open/close. Hand tighten it only, don't use a wrench. A common mistake is to not have the nut aligned properly when you start tightening it, just be sensible about it. An experienced person can do the whole job in under 2 minutes.
Anonymous
Level 3:
  • Master 528 Answers
Anonymous
Master
Level 3:
Answers
528
Questions
0
Helped
274437
Points
1396
Testimonial: "Thanks for the help!"
1helpful
Why won't water turn off?
YOU MUST SHUT OFF WATER FIRST!! Because you need to replace the valve stem washer. Most likely OO washer size, black hard rubber washer is worn out.
Remove the excursion (handle) one or hot and cold. Phillip screw or allen nut back of handle.
You will see a brass valve stem the handle was attached to. Use a crescent wrench and unscrew the stem and pull to remove.
Ar the bottom of the stem you will see the black washer. Remove the screw holding the washer in and replace with new. Reverse steps to install.
Hope this helps, I never know. Mike
Jul 04, 2015 • Home
Why shower head drip when faucet is open half way to mix cold with hot
If its single handle you have a bad ball valve or seals they make kits to replace the ball assembly for single lever showers....... you will need to have the water off for an hour or so to fix this...... shut water off at street or inside the house then remove the handle to shower if acrylic you remove the cap in middle of handle then remove screw then handle comes off once you do that there is usually a crown nut ( chrome doam ) that holds the stem into the body of shower manifold...... take a chanel lock or vice grip put cloth around it to keep from scratching and turn in counter clockwise direction once you remove the crown then the assembly will come out you may have to gerk it by attaching vice grip to stem ( btw always put cloth over drain to prevent you from losing anything...now that its out you have to go to big box store and match up a new ball assembly with seals and spring ( be sure to note if it is moen or whatever but i always take assembly and go .... they sell two kits one a seal and spring replacement and two seal spring and new ball go home take the old seal and spring out feel around with your finger to be sure all is smooth and put new ball in ( these are keyed meaning there is a notch to match up ) make sure ball and collar seats before you put the crown back on and there ya go! good luck
Aug 31, 2014 • Plumbing
3answers
Ball valve leaking
Probably need to re-pack the stem with stem packing thread
May 11, 2014 • Plumbing
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1helpful
Delta 476 faucet is leaking. I purchased the proper parts - RP4993 seats and springs and RP25 O-Rings for single handle faucet. Do we need any specific tools? Would you please be very...
http://www.faucetdirect.com/mediabase/specifications/476install_051710.pdf
Here is where to find the manual for your faucet. The only tools you should need are a pair of slip-joint pliars for the main ring and the hex key tool that came with the replacement parts. Remove the handle by loosening the hex screw on the underside. Make sure to turn off the water before you go any further and you will need to turn off both hot and cold.
Remove the dome-shaped cover either by hand or with some pliars.
Pull out the ball with the stem in it and underneath there will be two rubber washers with two springs underneath. Remove the washers and springs and put the new ones in. Put in the new stem (ball with stem) taking care to line up the slot in the side with the nub inside the base. Replace the round washer on top with the triangle hole in it and put the dome shaped cover back on.
Before turning the water on, use the back side of the hex-key tool to tighten the nylon ring that screws down into the dome shaped cover. Put the handle back on and try the faucet, if it moves too hard, loosen the nylon screw a bit, if too loose then tighten it. Once it "feels right" you can reattach the handle and turn the water back on.
I suggest turning on the water slowly and look for leaks. Not as difficult as it sounds.
Single handle faucet and handle keeps falling open doesnt stay up when turned off?
Sounds like a problem with the spring pressure on the ball or the ball itself. Try removing the handle from the stem. Usually a phillips screw underneath a snap on button in the center of the handle. Remove the screw and wiggle the handle off the stem. There should be a threaded collar on the top of the faucet body which exerts pressure downwards on the ball retainer and the ball itself. Try tightening this collar up "clockwise" a little bit and see if that stiffens the stem up to the point that the handle will stay in position. If this fails install a new rebuild kit. (ball, seats, o rings, and springs). It's helpful to know the faucet manufacturer before you go to the hardware store. Also helpful to have the old parts in hand to match up to the new kit. Note that you may have leftover parts from the kit as they often cover more than one model. You may find exploded parts diagrams on the manufacturers website to assist in disassembly. For example:
http://www.deltafaucet.com/customersupport/troubleshoot/bath-single-handle.html
Be sure to turn both hot and cold water supplies off before disassembly. Also, throw a towel or rag in the bottom of the sink to block the drain opening to prevent losing small parts down the drain. Generally, all you need in the way of tools is a phillips screwdriver and a pair of chanellock pliers. Another rag can be handy for protecting shiny finishes from the teeth on the pliers. If by chance you still have proof and place of original purchase, most modern faucets carry a life time warranty and will be replaced by the manufacturer or at least provide replacement parts free of charge. Though, generally, I find it far easier to replace parts rather than the whole faucet.
Jan 22, 2011 • Plumbing
Trying to repair a 2007 Subaru Outback. The rear view mirror housing came apart from the base. I detached the base, but cannot get the ball attached to the mirror into the base. How do I re-attach the...
you dont. they make it so you have to get a new one. my wife broke our in our car and went on e bay and got one for a good price. sorry went through the same thing
1helpful
Kitchen sink keeps dripping...how and what do I need to do to stop the dripping
Is this a single handle faucet or a double handle? If it's a single handle, you have to turn the water off then remove the handle. The set screw for this should be under a little plastic plug under the handle near the base of the handle. After you remove the handle, remove the housing cap to expose the valve ball. Under the valve ball are 2 small circular washers and springs. Pull them out and replace them. If it is a cartridge style faucet like a Moen, then you remove the u shaped retaining ring and pull the cartridge out.
If it is a double handle faucet, remove the handle and using a pair of pliers or a crestent wrench remove the stem. You will find the washer at the base of the stem held on by a screw. It could also be a washerless stem and in that case you will need to replace the whole stem.
If you have anymore questions, just respond to the post and I will get back to you as soon as I can.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
