This is almost
certainly a simple problem with your empty pump filter being clogged. The empty
cycle is timed and if it can't get all the water out in time because the filter
is blocked and slowing the empty down, then it will fail safe and won't step on
to the final spin cycle with excess water in the drum.
You need to
locate and clean the filter. Depending on the model (not familiar which with
the model you mention) there is probably a round filter cap on the front of the
machine at the bottom (It may be behind a small door or hidden behind a clip on
panel on the bottom)
Hello & Welcome to FixYa
F02 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
