Computers & Internet Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shortcut commands of insert,file,edit,format,tool,help,new
Anonymous
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Jul 06, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
136
Questions
0
Helped
21424
Points
432
HERE'S THE ANSWER TO YOUR PROBLEM:
I think your problem has something to do with the display of the MENU BAR of your browser. If the MENU BAR is displayed, you don't need to use the shortcut commands. This is what you've got to do:
1. Press the Alt Key. After releasing it, you will find a temporary display of the MENU BAR.
2. Click View
3. Click Toolbars. As you noticed, different toolbars are displayed. Click the MENU BAR, NAVIGATION TOOL BAR, and all the other bars that you want.
You will be surprised that all these commands will be permanently displayed on your browser.
NOTE: This process is applicable to Mozilla Browser.
Your problem is solved! Thanks. I hope it helps...
How do i download pictures from cd to mac
Easiest way. Make a new folder on your desktop. Depending on the OS, use the keys Command N or Shift Command N for a new folder. Title the folder. The Apple key immediately to the left and right of the space bar is the Command Key.
Insert the CD into the tray. When it opens drag the folder or files on the CD to your newly-created desktop folder. Remove the CD. You may now move the photos to IPhoto or any other location of your own choosing and edit them, turn them into a slide show or do with them what you will.
Using the same technique you can also transfer files ( any files, not just photos) from a USB device.
If your CD tray does not work or cannot read the CD (wrong format, etc) you have to progress to more ingenious solutions. Worst case, the screen will state "disk unreadable by this computer." Possibly formatted for Windows or some unreadable DAT format. Then you will have to go back to the source and reformat the files to JPEG, GIF, TIFF, PNG or some format your Imac will recognize.
tip
Steps to remove Windows 7 without affecting saved files or data: 1. Boot up and...
<span> <p>To format your hard disk during Windows 7 <a href="http://www.whitecanyon.com/how-to-format-computer.php#">installation</a>, you'll need to start, or boot, your computer using the Windows 7 installation disc or USB flash drive.<br /> <ol> <li>Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.<br /><br /></li> <li>Restart your computer.<br /><br /></li> <li>Press any key when prompted, and then follow the instructions that appear.<br /><br /></li> <li>On the <b>Install Windows</b> page, enter your language and other preferences, and then click <b>Next</b>.<br /> <ul> <li>If the <b>Install Windows</b> page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see <a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">Start your computer from a Windows 7 installation disc or US</a></li> <li><a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">flash drive</a>.</li></ul></li> <li>On the <b>Please read the license terms</b> page, if you accept</li></ol> <ol> <li> the license terms, click <b>I accept the license terms</b>, and then click <b>Next</b>.<br /><br /></li> <li>On the <b>Which type of installation do you want?</b> page, click <b>Custom</b>.<br /><br /></li> <li>On the <b>Where do you want to install Windows?</b> page, click <b>Drive options (advanced)</b>.<br /><br /></li> <li>Click the partition that you want to format and click <b>Format</b>.</li> <li> <ul> <li>If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the <b>Delete</b> option for each partition. Once you have deleted all of the partitions, select thepartition and click <b>Format</b>.</li> <li><br /></li></ul></li> <li>Pick the formatting option that you want.<br /><br /></li> <li>When you've finished formatting, click <b>Next</b>.<br /><br /></li> <li>Follow the instructions to finish installing Windows 7, which include naming your computer and setting up an initial user account.<br /> <ul> <li>If you do not want to reinstall Windows 7, you can cancel the installation at this point and keep your newly formatted drives.</li></ul></li></ol></span>
on Nov 25, 2010 • Computers & Internet
What do I have to press for it to be command prompt, because I'm not sure?
open cmd run-> Cmd or you can run the dos one by creating a shortcut the shortcut name is command.com
cd ( command)
for ex: cd/ gets u into the main hard disk page
dir to make your cmd read files and info that hard disk contain
other ex: when you dir the file yo can enter them by this command
cd File Name
ex 2 : cd program files
that will get you into program files
Ex3 aND its the most IMPORTANT To Change the hard disk ( the hard disk were you are ) Hard disk Name:
Ex 4 there is a way you cant write and save your reminders etc.
By Typing edit
a window will pop up
Hint You can write help to get all of the commands can use
I Hope its helpful
How do i use compare it
Total Commander (www.ghisler.com, ex. Windows Commander) is a popupar two panels file manager. If you are still using Explorer for your routine tasks, you should definitely give it a try. TC has built-in file compare tool, but it is limited to standard features and does not allow merging.
Using new features of TC 7
Among new features of v7 in TotalCommander we can find an ability to define external compare utility, which TC will use instead of internal tool. It gives us 2 main advantages:
  • CompareIt will be used from internal Folders comparison tool (useful if you are not using our Synchronize It!)
  • Now we can quickly compare 2 files, selected in same pane!
  • Compare It can be used to compare files within archives
Using this nice feature requires a bit of manual work:
  1. Find wincmd.ini file - it's location is listed in Help>About
  2. Open it in any editor and find [Configuration] section
  3. Add this line under found section:CompareTool=c:\Program Files\Compare It!\wincmp3.exeOf course, change CompareIt path to what you have in your system
  4. Save file and restart Total Commander.
  5. To ensure that everything is working properly, select 2 files in same pane and choose File>CompareByContent command from menu. CompareIt should open with your selected files.
We will use button bar feature of TC - basically this is toolbar with shortcuts, used to quickly start applications with parameters from current panes.
To add shortcut to Compare It!, simply drag it and drop to the button bar. New button will appear, you can try to start application by clicking it.
Now we have to change parameters in order to compare files currently selected in left and right panes. Click our new shortcut with right mouse button and choose "Change..." to access button properties dialog.
We are interested in Parameters field, fill it as shown: art_tc2.gif
Quite a lot of variables can be used in parameters. But we will use only these (excerpt from TC' help file):
  • %P causes the source path to be inserted into the command line, including a backslash (\) at the end;
  • %N places the filename under the cursor into the command line;
  • %T inserts the current target path;
  • %M places the current filename in the target directory into the command line.
So %P%N becomes full path of current file in active pane, %T%M - full path of selected file in second pane.
Tip: Since Compare It! supports zip archives, you can also use created button to compare file with it's zipped version. To do this, select file in one pane, and archive in second one. Note that file to compare can reside deep in folders within archive, Compare It! will find it anyway.Using FileName Auto-Complete featureBut you can get even more by using unique Compare It! feature, designed especially for this case. Add to button bar another shortcut to Compare It!, and change parameters to these: art_tc3.gif
To use this button you don't have to select required file in second pane - just select file in active pane, and change your second pane to show folder were another file is located. This single button will save you several minutes every time you need to compare files with same name.
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- message occurs for FORMAT - I click on OK button, Format window open - Capacity shows 62.4GB, System= Nill, I select Quick format option...
first try to format in command line
Start
go to RUN
Type CMD and press enter key
in command window type format H:/fs:FAT (H: stand for my Pen Drive name change it if you have different)
press enter key
yes to all message appear
now you formatting start
if not so try this: 1000% work
download any low level formatting system and format from that or you need 3rd party formating tools like HP format tool to format RAW to FAT,
if still not work it mean your PEN Drive got Damaged and you have to purchase a new one.
Do vote me if this help you.
Will not format to full 1 gb it is a verbatim
Ithink it could be due to virus activity. Some virus make the contents of thedrive hidden, that's why user can't see the files and the space available for use is less than thecapacity and also can not open the drive. It issuggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may showthe hidden files. If can not show ,hidden file (tools >folder option>view> check on show hidden file>check off hide protected and checkoff hide extension) now can see all hidden file in c drive. If not think...... For ensure again run>type> msconfig > hit can not open ms config if virus effected run >type> regedit>hit>can not open registry if virus effected run >type >gpedit.msc>hit can not open group edit policy if virus effected Otherwise, ifyou don't have any vital data on the drive, just format it in another pc.Pleasenote, before insert the Pen drive .Go to run command from start menu OR Press Win key+R and type gpedit.msc and hit>Usser configuration >system>turn off auto play >enable>use down arrow key select all drive >apply >ok. Control panel>administrative tools > service>select any word in right side and presss for select Shell Hardware Detection> d -click >use down arrow key>disable >start. And now can insert pen drive and format. Hope this wouldfix the issue and . Youshould fully scan by f-secure bootable cd or any another antivirus bootable cd.Just insert the disk and restart. Follow bellow the download link. http://www.f-secure.com/en_EMEA-Labs/security-threats/tools/rescue-cd you wouldbe able to enjoy the full capacity of the disk. Try to be sure follow these youshould delete partition and create new partition and format your all drive. Now install fresh O.S.
Hope this helps
1helpful
I am the new user, Kindly support me with out charging users guides on how to use ms word easily with short cut keys
Open up Word, click on Help >> MS Office Word Help and a whole bunch of online solutions will appear on the right side. Have fun.
For example:
About shortcut keys
You can quickly accomplish tasks you perform frequently by using shortcut keys - one or more keys you press on the keyboard to complete a task.
For example, pressing CTRL+B changes the selected text to bold, just as clicking Bold on the Formatting toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) or selecting Bold in the Font dialog box (Format menu) changes the selected text to bold.
Printing a list of shortcut keys
If you frequently refer to the Help topics that list shortcut keys, you may find it helpful to keep a printed copy of those topics. In Help, locate the topic you want, and then click Print .
You can also run a macro (macro: An action or a set of actions that you can use to automate tasks. Macros are recorded in the Visual Basic for Applications programming language.) that creates a list of the current shortcut key assignments, and then print the list.
On the Tools menu, point to Macro, and then click Macros.
In the Macros in box, click Word commands.
In the Macro name box, click ListCommands.
Click Run.
In the List Commands dialog box, click Current menu and keyboard settings.
Click OK.
On the File menu, click Print.
Customizing shortcut keys
You can customize shortcut keys in Microsoft Word by assigning shortcut keys to commands that do not already have them or by removing shortcut keys you don't want. If you don't like the changes you make, you can return to the default shortcut key settings at any time.
Using shortcut keys with different keyboard layouts or Word as your e-mail editor
Shortcut keys mentioned in the Help topics, menus, and dialog boxes refer to the U.S. keyboard layout. Keys on other layouts may not correspond exactly to the keys on a U.S. keyboard. If the language of the keyboard layout you are using doesn't match the language you set for Microsoft Word or Word Help, you may have to make adjustments when using shortcut keys or change your keyboard layout.
If you are using Word as your e-mail editor, some of the shortcut keys listed may not be available or may produce different results.
1helpful
Copy and Paste shortcuts CTRL C and CTRL V no longer work!
Please try the following:
In Word go to Tools/Customise. Click on the Commands-Tab.
The Click the Keyboard button.
In the Categories block Click Edit.
In the the Commands Block click Edit Copy.
On the Current Keys block check to see if you have Ctrl+C.
If not click assign and assign Ctrl+C.
2helpful
2answers
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Grand Canyon Tech
Grand Canyon Tech
