20 Most Recent Microsoft Windows Vista Ultimate Edition Questions & Answers
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.2
Locale ID: 1057
Additional information about the problem:
BCCode: f4
BCP1: 00000003
BCP2: 8A7FE5A0
BCP3: 8A7FE6EC
BCP4: 839F1DC0
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini013111-01.dmp
C:\Users\PORTEGE PC\AppData\Local\Temp\WER-87235-0.sysdata.xml
C:\Users\PORTEGE PC\AppData\Local\Temp\WERFD61.tmp.version.txt
Microsoft... | Answered on Apr 29, 2019
Adobe Premiere
Microsoft... | Answered on Apr 24, 2019
I can play .vob files with a cool media player called VLC player, which plays everything I throw at it. I recommend you download it from here:
http://www.videolan.org/vlc/
and when you install it, set the File Associations to play everything with VLC, that'll let you double click on a .vob file and play it automatically.
VLC has a much lighter 'footprint' than Windows Media Player, or Nero or many DVD players,and has amazing codec-support already included.
If the .vob files are encrypted, then maybe that is slowing down your laptop, but that is not the only reason for this to happen.
If it still restarts automatically, you may have picked up malware from downloaded movies, and need to download Spybot and scan and immunize your hard drive. Spybot is completely free. Trust me, i don't like paying for things :)
It's also possible that you need to clean up your registry and your drive with a free program called ncleaner. you can find that here:
http://www.nkprods.com/ncleaner/
I suspect you will be successful with VLC player, though. Enjoy your movies :)
Chris
Microsoft... | Answered on Apr 18, 2019
Use VLC player to play any kind of video files
Microsoft... | Answered on Apr 16, 2019
java editor is a text editor which probably understands java language synthax and can automatically call java to compile your code.
Java software is a program written in Java programming language which is interpreted/executed by JVM(JAva virtual machine) on a target computer.
Your question is a rough equivalent to : What is a difference between typewriter and a recipe book written in English language
Microsoft... | Answered on Apr 12, 2019
It will depend on PC operating sys. The 'cutting' drivers as you put it, work through the design software, so once againg it depends what your using
Microsoft... | Answered on Jan 28, 2019
ok liscense doesnt expire you just need to register your system
Microsoft... | Answered on Jan 26, 2019
ok...first u must format your hardisk...then install windows vista without entering it's cdkey...after completed installing, u have 30days to verify your vista....just go to my computer icon and click right to choose properties...at the bottom screen shown next is windows activation..enter your product key there while connecting to internet...from there u can verify your original cdkey...hopes it help... ; )
Microsoft... | Answered on Dec 27, 2018
There is probably a compatibility problem with mail and outlook.
What about installing Outlook onto your Vista computer?
Microsoft... | Answered on Dec 06, 2018
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Microsoft... | Answered on Oct 24, 2018
ISI is a quality standard certificate in India allotted by Indian Standards Institute.This mark certifies that the product or services comply with the standards specified by Indian Government and and is developed as per the standards of Bureau of Indian Standards (BIS). Most of the electrical appliances and kitchen accessories are required to have ISI certification.
https://www.gsbtaxation.com/in/isi-certification-consultants-in-bangalore/
Microsoft... | Answered on Sep 17, 2018
Backup your data files (external hard-drive or burn some DVDs).
Then, reinstall Vista -- much quicker than trying to "trouble-shoot".
Microsoft... | Answered on Jul 13, 2018
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Microsoft... | Answered on May 22, 2018
MozBackup is a simple utility for creating backups of Mozilla Firefox, Mozilla Thunderbird, Mozilla Sunbird, Flock, SeaMonkey, Mozilla Suite, Spicebird, Songbird and Netscape profiles.
It allows you to backup and restore bookmarks, mail, contacts, history, extensions, passwords, cache etc. It's an easy way to do Firefox backup, Thunderbird backup ...
Microsoft... | Answered on Apr 20, 2018
hi Robert.
go to this link and have read up it will help you a lot, or it should do.
what is service pac 2 Google Search
Microsoft... | Answered on Apr 06, 2018
Sounds like the farm town server, whatever that is (and I'm guessing a Windows Domain Server) is broken up about your version of Windows more than anything. Look up bits about Window Vista Ultimate (at Microsoft.com, though Google will find it fine) and whatever kind of server the town has and you'll find the bit to run so the server will keep you authenticated (connected.)
if you have ms office installed on your pc you can access the ms office word through "Start>All Programs>MS Office>Ms office word" you can also try to launch it using Run. Click Start > Run and type winword
if cannot found error displays you probably not installed ms office. better purchase and install it then.
Microsoft Windows Vista Ultimate Edition Logo
5,173 questions posted
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VISTA Microsoft
  • VISTA Microsoft
Most Popular Question
download e mail from yahoo account
  • Computers & Internet
