Roland GW8 Keyboard Arranger Logo
Posted on Jul 05, 2011
I am new to the Gw8 roland. I accidently found a guitar sound (170 ) that with incredible effects. When I went back to enter that tone again the effects were not there. What did I do and how can I get that sound back as it was and incredible duplicate of real guitar sounds
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
280
Points
I have a GW-8 Roland. its automatically plays. What may be the reason and how to repair?
please help
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
How to connect Gk3 equipped guitar to Electric Piano or Synthesiser ?
A Gk3 cannot be connected directly to an electric piano or synthesiser. The 23 pin DIN connector connects the GK3 / GUITAR to a Roland guitar synthesiser which produces the synth tones . This unit can be connected via midi cable to any external keyboard or synthesiser...to produce different or varied tones from the external synth ........provided the devices are able to communicate with each other...see the midi implementation charts for each device for information....
11helpful
2answers
How do I factory reset a BOSS ME-70 effects pedal
press pedals 3 & 4 at the same time to swtich to Manual Mode. Hold down EDIT/EXIT and press the MOD pedal. Press WRITE twice.
2answers
I have a Roland AC-90. During a gig last Sunday I had my Taylor acoustic guitar and a Shure mic cutting out. There would be a break in sound - both guitar and voice would go - and then it would all come...
I would expect there is bad soldering or a circuit board crack. Inspect the soldering aound the leads, especially pots and heavy components. Finding all the retaining screws can be frustrating. Expect the screws for the handle to also attach to the amp chasis. They are often hiodden under plastic caps.
My boss me 25 pedal's sound isn't as clear and good as the demos' sound. My amp is a randall RT100 which is a valve amp and my guitar is an LTD with the custom pickups. so the problem is the setting i'm...
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
I wanna learn the circuit diagram of roland gw8
You would have to get the circuit schematic from Roland and they may not give that out as it is proprietary. I have circuts for Fantom and Yamaha Tyros and believe me you won't learn anything beyond the block diagram. The circuit details are BURIED inside chips that you probably can't even get data sheets on and certainly can't get or understand the firmware of the internal operating system.
I want indian tones for roland gw 8a?
Roland Provide Us a Huge Asian Collaction , But For Indian Collaction We Have To make Aforts for Making a Tone. And I Dont know How the edited tone will be save ointo the bank but edited tone must be saved into style and we can save it from WRITE button As A PERFORMANCE.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
