20 Most Recent Roland Boss ME-25 Guitar Multiple Effects Pedal Questions & Answers
BOSS ME-25 SCHEMATICS
Request the schematic diagrams from Boss.
3/2/2022 5:50:01 PM • Roland Boss... • Answered on Mar 02, 2022
My boss me 25 pedal's
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
9/29/2017 2:12:14 PM • Roland Boss... • Answered on Sep 29, 2017
Hi, I have a problem, when pedal is turned on all
Your best bet would be to contact Roland Customer Service. The link for the USA is- Support Roland Roland Support Service Repair Service Center Locator Roland Company Contact Us
7/29/2016 12:57:45 AM • Roland Boss... • Answered on Jul 29, 2016
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
2/5/2016 7:24:08 AM • Roland Boss... • Answered on Feb 05, 2016
0answers
I need operation manual for a Boss me-25 Guitar multiple effects
Manuals can be a pain to find,you might take a look at this,,turbo start page;(cms.rolandus.com/assets/media/pdf/ME25ts.pdf)You have me curious,so ill keep searching.Used to be easy to find a manual for everything.
7/28/2012 12:33:41 AM • Roland Boss... • Answered on Jul 28, 2012
When i plug it in, it dispays some hard to understand letters like
If it functions fine otherwise, it likely is simply digital noise. This can happen if the pedal is simply unplugged without powering down, or dirty contacts in a switch, marginal sontacts between the display and the circuit borad or an electrolytic capacitor is excessivley leaky on the main power buss.
4/6/2012 2:33:23 PM • Roland Boss... • Answered on Apr 06, 2012
Fix boss me-25
Is the power supply correct and power plug fully seated into the pedal? Are the other plugs the correct length and firmly seated?
4/6/2012 2:02:16 PM • Roland Boss... • Answered on Apr 06, 2012
2answers
When I power my Roland D20 up, all I get is bars
Hello. Hello. Generally the upper LCD display of bars is an indication that the internal battery is on it's way out and needs to be replaced.
In case you do not have the owner manuals, they can be downloaded from this address - enjoy: http://soundprogramming.net/manuals/Roland_D-20_Manual.pdf
3/28/2024 1:20:25 PM • Roland Music • Answered on Mar 28, 2024
I have a ROLAND BK5 keyboard instrument that has no sound out of speakers or headphones but it has new ribbon cables all components are working just fine except the sound
I wonder why the ribbon cables have been replaced as they do not fail. Check the keys actuate the contacts properly.
11/1/2023 7:57:00 AM • Roland Music • Answered on Nov 01, 2023
2answers
Damper pedal piano doesn't keep the tone properly
I can't! In my opinion, no. Start drift boss customize your car by choosing different colors and patterns.
10/31/2023 1:49:23 PM • Roland Music • Answered on Oct 31, 2023
ROLAND G70 . I HAVE LOST THE VISUAL OF THE MIDI
4/17/2023 4:19:13 PM • Roland Music • Answered on Apr 17, 2023
2answers
My Roland FP4 piano has suddenly ceased to power on. Is this fixable?
most likely we dont have crystal balls --need to have diagnosed for problem
4/10/2023 12:49:18 PM • Roland Music • Answered on Apr 10, 2023
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM • Roland Music • Answered on Jan 05, 2023
Roland Boss ME-25 Guitar Multiple Effects Pedal Logo
14 questions posted
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
boss me 25 schematics
  • Music
