Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
I have the same problem. When I go turn tv on the backlight looks to come on but no image/channel label/menu/volume show then it turns off with power light going from green to a red then off. Then tv turns on again then off again on its own and then it finally stays off unless I press power button on remote/tv and then it just does what I mentioned above as in repeats itself.
