20 Most Recent Sharp Aquos LC-37GD6U 37 in. LCD HDTV Questions & Answers
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Sharp Aquos... | Answered on Jul 09, 2019
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sharp Aquos... | Answered on Mar 09, 2018
check the warranty period
picture board problem so if not under warranty get a proper diagnosis done and a quote
Sharp Aquos... | Answered on Jan 28, 2018
the TV possibly does not require use of a converter box .some times we OVER THINK things
Sharp Aquos... | Answered on Jan 16, 2018
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sharp Aquos... | Answered on Mar 12, 2017
Keep your mobile camera on press any key from remote you will get flash light in mobile.It means remote is ok.
Press On/Off switch from LED Tv and checked tv is on or off.
If Green light is blinking but tv not getting on follow as per attached file.
Sharp Aquos... | Answered on Jul 02, 2016
One of ur fuses has gone bad and u must call Sharp Co.
Sharp Aquos... | Answered on May 27, 2016
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Sharp Aquos... | Answered on Mar 02, 2016
GOOD NEWS - - According to the Sharp Technician I just spoke with a "Service Bulletin" went out to all their techs about the sound issue on these Sharp Aquos. I'm having the exact same sound probem and I'm in the process of having the technician come out at no charge so call the number given in Solution #6 and #9 (1-800-237-4277) and keep pressing #1 until you get a technician. Have your serial number ready and they will need your name, address and telephone #. They will then give you a case number and transfer you to dispatch (which closes at 5pm central). Thanks everyone for your help and posts - you made our day!!!
BTW - We also have the problem of the TV turning on and off by itself but the technician said they had not received a service bulletin about that yet.
Sharp Aquos... | Answered on Sep 03, 2015
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Sharp Aquos... | Answered on Aug 19, 2015
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sharp Aquos... | Answered on Jul 25, 2015
It is likely that your Sharp TV has developed a power supply problem
Sharp Aquos... | Answered on Mar 31, 2015
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Sharp Aquos... | Answered on Dec 31, 2014
You probably are not getting a picture.
Sharp Aquos... | Answered on Dec 08, 2014
I have the same issue and cannot locate a replacement
Sharp Aquos... | Answered on Nov 24, 2014
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
331 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
loss picture lcd tv when first turned
  • Televison & Video
