On the Wheelrighter 3500, what are te magic keyst to type on paper as I type? Right now, it is set to type across the screen and print after I push return. Any help is appreciated :)
If it types as you press the kets delay print is turned off, press the print mode key on the r R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
Make sure to follow these steps:
1. load the appropriate type of paper into the All-In-One. Place the paper against the right side of the paper support with the print side facing you. Make sure you select the paper size for your document.
2. Squeeze and slide the paper guide to the left edge of the paper.
3. Make sure the All-In-One is turned on.
4. Click File -> Print.
5. From Print dialog box, click Properties, Preferences, Options, or Setup (depending on the program).
6. From the Paper Setup tab, select the paper type, paper size, and orientation.
7. Once you have applied all the settings you want in Print Properties, click OK at the bottom of the screen to return to the Print dialog box.
8. Click Print to complete your task.
The paper settings in the print driver must match what is loaded in the product.
NOTE:
These changes do not change the default print settings. The print settings return to default the next time the program opens.
Open the document that you were trying to print when the issue occurred.
Click File , and then click Print . The Print dialog box opens.
Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
From the Size is drop-down menu, select the paper size that matches the paper in the tray.
From the Type is drop-down menu, select the paper type that matches the paper in the tray.
Click OK , and then click OK again to print the document.
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size: 1. On the home screen, touch Menu button 2. Touch Paper Menu 3. Touch Paper Size/Type. Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP Feeder Type to appear as a menu item. 4. Touch the right or left arrows to select the same size paper from all paper sources to be linked. 5. Touch the right or left arrows to select the same type paper from all paper sources to be linked. Note: When the Size and Type settings are the same for any trays, the trays are automatically linked. 6. Touch Submit. Submitting changes appears. 7. Touch Home to return to the home screen. Hope this helps.
Solution one: Print on heavier paper
Try printing on a thicker type of paper.
Solution two: Check driver settings
If printing on plain paper, make sure the driver settings are set to Plain Paper.
To change the driver settings, click the
Properties
button in the Print window.
If the Paper Type is not set to Plain paper, click the drop down box and choose
More
Find and click
Plain paper
, then click
OK
Click
OK
to return to the Print window and click
OK
to continue printing.
In Word 2007, use the Mailing > Envelopes > Options section.
In 2003 I think it was under Tools > Envelopes & Mailings > Options.
There you'll be able to specify if the manual feed is top first or edge first, to the left, centered, or to the right, and how far over and down to place the address and return address.
Try this:::
The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
Open a document in the program being used to print.
Click File , click Print , and then click Properties . The product Properties dialog box appears.
Click the Paper/Quality tab.
Choose the appropriate paper size from the Size is drop-down menu.
Choose the appropriate paper type from the Type is drop-down menu.
Click OK and then click OK again to print the document..
If the issue is not resolved, continue with the next step.
NOTE:
If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
Let me know if it helps or I can research it some more.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
