Home Logo
Posted on Jun 16, 2011
My drain is slow. i cannot figure out how to remove it to pull out the hair clogging it. what do i do to fix this?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
50
Points
Grab a wire hanger and push it down there wiggle. It alot this. Usually works
2answers
How to unclog a bathroom sink slow drain when nothing has helped?
If the person(s) using the bathroom has long hair then likely that's the problem. You need to remove the stopper and use a "hair snake" that will reach down the drain into the trap and pull the hair mass out.
See following video.
https://youtu.be/X2QIz1jAJy8?si=mJPR4BIh_szF8n9y
Since you used caustic drain cleaners you need to take APPROPRIATE SAFETY PRECAUTIONS to avoid chemical burns to skin and eyes.
OR, call a professional.
tip
Tub drains slow
does your bathtub drain slow, and toilet not flush? dont call a plumber just yet, Every fixture in your home should have a air vent associated with it. the vents allow gases to escape and are necessary in allowing the waist water to flowout and down the pipes. most vents lead up through the roof, these are usualy 2" in diameter and raise up about 20" from the roof. there are other ventsin and around the home like the drain pipe for your washer or the overflow drains in sinks and tubs. If you have a tub that drains slow its usually hair buildup in the trap and is simple to clear. If you have a problem like the one i had and you've tried everything and it still wont drain the vent may be clogged. In my case the toilet wouldnt flush allong with the tub draining very slow, I threw every thing i could at the problem including removing the toilet and running a power snake. You can imagine how i felt when i put the toiket back in place and when i flushed it nothing happened:( after some thought i went to the tub and removed the chrome cap 0ver the overflow and ran a wire with the end bent like a hook as i pulled the wire out the toilet flushed, on the end of the wire was a clump of hair . problem solved!
on May 05, 2012 • Plumbing
tip
Slow shower drain fix.
This tip will show you how to fix a slow tub drain. In my experience most slow shower and tub drains are caused by hair. Usually within reach of a wire hanger. Since you probably do not have all the proper tools, you must be careful not to damage your drain line.
The trickiest part with most shower drains, is the pop up assembly.Most times the hair is caught on the pop-up components. If you have a pop-up, check with your local hardware guy to show you how it works and is assembled. On a pop-up, you'll have to take the drain plug/cap off. have the cap in up position, and get your eyes below the cap rim, you will see a small set screw, a couple turns and cap should come off, do not take set screw all the way out. If you see hair on assembly after taking assembly out, remove the hair and run some water to see how your drain is working. If that does not fix your slow drain, you should stop there and call a plumber, because that means you blockage is further down the line then you'll be able to reach.
If you have no pop-up assembly. Untwist hanger, make as straight as possible, then with a pair of needle nose or any pliers you have, go about a half inch in from the hook side. Make a U bend, about the same size and shape of the end of a paper clip. Go in drain a inch and turn hanger in a circle trying to catch the hair blockage. Twist a couple times and pull back gently, do not push hanger in to far, you might break your pipe or the hanger may get caught in the p-trap or even worse drum-trap,(older houses tend to have drum-traps, I suggest not to even attempt to clear any blockage were a drum-trap is involved,call a plumber)
If its hair, you will see this black sludge looking hair ball that may make you sick. Don't worry you'll be happy when all is said and done, and you can shower without standing in your own filth. If its not hair, you probably have a more serious problem. Call a plumber and make sure your plumber gives free estimates.
Other Tips:
http://www.fixya.com/support/r5197305-stop_water_sweat_solder_water_line
http://www.fixya.com/support/r5238897-reset_toilet
http://www.fixya.com/support/r5245506-leaking_shut_off_valve_hard_close_shut 4d20c6a.gif
on Jul 01, 2010 • Plumbing
Clogged shower drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
Dec 04, 2013 • Home
Dont drain
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 • Plumbing
My bathtub drain is American Standard circa 1927. The tub stopper is actuated by turning a knob connected to a linkage connected to a rod, connected to a yoke which threads onto a sleeved pipe which...
your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Jun 28, 2009 • Plumbing
1helpful
Ice buildup on bottom of freezer
yes, the drain is clogged, remove all food from frige and freezer and defrost with a hair dryer,go the the freezer section this is where the issue is, you need to poor hot water into the drain trough located just below the evaporator, chase the drain with a coat hanger with the hair dryer on the coat hanger this with heat up the coat hanger enough to melt and free the clog.
nbcrca:)
2helpful
Bathroom tub drain clogged
If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
You may consider replacing a lever stopper with a "twist and twirl" type.
If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
