20 Most Recent American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Questions & Answers
Either water pressure is low or valve is partially blocked.
American... | Answered on Nov 15, 2017
No that flaw it is just not adjusted right. All that you need to do is adjust the chain so the float can not get under the flapper. To do this remove the hook from the flush handel. Once that is done adjust the chain by moving the hook down the chain a couple of links or un till you have about 2 links of slack.
Good Luck
American... | Answered on Aug 01, 2015
Adjusdt the float level, still same problwm replace fill valve assembly.
American... | Answered on Aug 23, 2014
your float is stuck
American... | Answered on Apr 26, 2014
if u pull the lid off the tank you will see that the water level and the amount of water delivered for flushing is adjustable, most have a little float that u can move to deliver more water before the tank valve shuts off, move the foam float down to give more flush water, also u should be able to set the tank level higher, have done this on both my low flow's and got good results.
American... | Answered on Nov 12, 2009
Adjust the floating stopper in the tank to allow more water to fill the tank
American... | Answered on Jul 17, 2009
sometimes theres caps on top pop the cap and tighten the screws and sometimes there are nut or wing nuts on the bottom...simple enough for you?
American... | Answered on Sep 06, 2019
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American... | Answered on Jul 12, 2019
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet.
Then....visit this link:
https://www.americanstandard-us.com/parts-support/faqs/toilets
Good Luck!
American... | Answered on May 06, 2019
American Standard Flowise 2480.216.020 White Dual Flush Right Height Elonga Logo
21 questions posted
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
dual flush american standard 4035 keeps
  • Home
