Uniden D16602 Twin Cordless Phone Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intercom does not work - Uniden D16602 Twin Cordless Phone
notatechie
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 10, 2012
notatechie
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2921
Points
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
  • 2 more comments
  • Anonymous Dec 17, 2012
    We are having the same problem with our new phones. After choosing a handset, nothing happens. Is there another step we are missing?
  • Anonymous Feb 05, 2013
  • notatechie Dec 10, 2013
    1. Press Intercom
    2. Scross to handset you want to intercom, 3. Press Menu|Select button
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on Jun 15, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528091
Points
3536
Lets make sure you are following these standards and if it still does not work, let get to the troubleshooting portion of this assistance.
Handset to Handset Intercom
??Whenever the phone is in standby, you can make an intercom call between
handsets without using the phone line.
??You can make an intercom call from any handset, but only two handsets
can be in an intercom call at any time.
??If an outside call comes in during an intercom page, the phone cancels the
page so you can answer the incoming call.
??If an outside call comes in during an intercom call, press Talk/flash to
hang up the intercom call and answer the outside call.
To make an intercom page
Press Intercom/clear. Select the handset you want to talk
with, or All to page all handsets at the same time.
To cancel a page
Press End
To answer a page
Press Intercom/clear or Talk/flash.
To end an intercom call
Press End. Both handsets return to standby.
2answers
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
speaker on the base or talk/flash on the handset to hang up the intercom call and
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Intercom uniden D1688
After reading the manual over and over with no success, I got the hint to successfully do an intercom call by reading a post from a website.. The manual says to press the Intercom buttom. Then select the phone you wish to intercom with (or All phones) - do this by using the up-down button. The step left out of the manual is: THEN press the MENU key. It works perfectly!!
My intercom doesn't work
plse switch off all conntion remove clean wire reset
Interference in our wireless intercom
Wireless routers operate on 2.4GHz frequency. It's very possible that your intercom is in the same frequency range causing inerference. Try and find the frequency your intercoms operate on. If you can't find it on the unit, search the internet for the name brand and maybe you will find the info. If this is that case, (as I suspect it is), the only alternative I can suggest is to change your intercoms. Be sure to check the frequency of the new intercoms before purchasing. Anything but 2.4GHZ should work fine.
Transfer Intercom Call
This works on a TDA, so I think it will also work on a TD. The key is 43. When you page someone, you can pick up that call via 43 which gives you an intercom call. Now, your transfer key works, putting the other intercom call on hold and giving you dial tone.
Carl
Blocked Intercom
If you do not have a button to press to call him, you must press the intercom btn and dial his intercom # . to find his intercom # , go to his phone and dial feature 00. His intercom # will be displayed. press feature 00 to exit.
2answers
Partner 18D intercom not working
If you mean intercom, as in Speaker/overhead paging, then the buttons need to be reprogrammed to access the intercom. If you mean calling from one avaya phone to another, then the system is more then likely fried. from your system press the intercom button, 61. that should give you the paging access that I think you are looking for.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
