20 Most Recent
Avaya Corded Phone avaparp18d Questions & Answers
Avaya phone system to many lights
The extra light means there is something programmed for that location. I would go into the extension programming and see what that button is set for. It could be an unused line or a feature not labeled.
After power outage incoming calls cause all lines to light up
If this is happening on the entire system, then make sure you have the number of lines programmed correctly. If this is correct you may have a bad processor card. If this is a happening on an extension only, then the port/card may be damaged I would temporarily move the extension to another port on a different card and see if the trouble follows. If it does you have an issue with the phone not the port/card.
How do I change the Mail Greeting recording
For a Partner 18D phone the process is a little different depending on the VM version you have. In general you press Intercom 777(gets you into voicemail) enter your password(default is 1234 or 123456). This is where the various system commands change. Listen for Mailbox Options or Greetings option. Press that button and you can setup, change or delete greetings.
How to delete messages?
For most of the Avaya mail systems it is *3 after you have logged into your voicemail. If this is incorrect just listen to the prompts in your voicemail it will tell you.
