20 Most Recent Panasonic KXDT343 Phone Questions & Answers
Relocate Extension to New Handset Location
Walking extension dial*727 extn number then the pin
12/9/2022 5:39:50 AM • Panasonic... • Answered on Dec 09, 2022
My Panasonic KXDT343 phone is giving an error message when I try to change the time, it keeps saying limit exceeded. How can I get passed this?
Question edited for clarity. Wrong type of passed / past.I can't find that error message anywhere, and am guessing that you are in a section that isn't part of setting the time. First completely disconnect the phone for 5 minutes and then plug back in. There is a video here on setting the time.https://www.google.com/search?q=panasonic+kx-dt343+set+time..
3/15/2022 5:02:04 PM • Panasonic... • Answered on Mar 15, 2022
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
3/15/2022 4:06:17 PM • Panasonic... • Answered on Mar 15, 2022
0answers
manual
0answers
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
3/5/2015 12:46:29 AM • Panasonic... • Answered on Mar 05, 2015
2answers
How do I turn off
There are messages or the light would be out. On an idle phone, press MESSAGE. Look at the display. It will tell you where the message came from and the 3rd soft key will let you CLEAR the message. When they're all gone, the light will go out.
Carl
1/6/2015 12:15:16 PM • Panasonic... • Answered on Jan 06, 2015
2answers
How do you cut the intercom volume down? Every time the nurses at my job talk over the intercom, my patients and I cringe because the volume is so loud. Is there a way to cut it down on my side and ad
While the intercom or speaker phone is in use, you set the volume. Same as with the ring tone but it has to be used to set volume.
12/9/2014 4:48:55 PM • Panasonic... • Answered on Dec 09, 2014
Panasonic KXDT343   Phone Logo
280 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
voicemail button redirected phone line
  • Lands Phones
