20 Most Recent Panasonic KX-TG1033S Cordless Phone Questions & Answers
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
Panasonic... | Answered on May 06, 2019
The batteries may have been inserted incorrectly.
Panasonic... | Answered on Nov 27, 2018
inter this code: 726276642
Panasonic... | Answered on Jan 31, 2018
Be sure you have selected tone dialing (as opposed to pulse).
Panasonic... | Answered on Dec 13, 2017
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Panasonic... | Answered on Nov 25, 2017
I am sure that is a service related issue and no the phone itself.
Panasonic... | Answered on Apr 26, 2017
Try switching batteries with one of your other handsets known to be in good working order or replace the batteries in the handset with the problem with new ones
Panasonic... | Answered on Apr 22, 2017
Go to menu then initial setting then call block. Scroll to find the blocked number and choose erase. That erases it from the call block menu on your phone.
Panasonic... | Answered on Jan 04, 2017
take a volt meter and check the contacts the phone sits on in the base station, there should be around 5 volts DC there, if there is I would replace the batteries in the phone, if there is no voltage at the charging contacts in the base then the base station is defective, another quick way to determine the cause of the problem is take the phone out of the base station and put it into one of the other phones chargers, then if the phone does charge up the base station charger is defective, u will need to replace the phone or not use the base station for charging. these are not repaired except under factory warranty.
Panasonic... | Answered on Dec 16, 2016
Panasonic KX-TG1033S Cordless Phone Logo
769 questions posted
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
worked fine until today only rings once
  • Lands Phones
